Old 02-21-2021, 12:33 PM
ErikW's Avatar
ErikW ErikW is offline
We kinda went over that in post #84. If we feel we don't have a sufficient amount of drop then we will incorporate a reservoir and scavenge pump setup.
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
  #122
Old 04-13-2021, 12:16 PM
ErikW's Avatar
Default Progress
Sneak peek. More very soon.
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #123
Old 04-13-2021, 01:06 PM
GTOGEORGE's Avatar
Race car stuff........I like!
GTO George
  #124
Old 04-13-2021, 01:40 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
Can I start my build over now?
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well.
>>My 73 Build thread
  #125
Old 04-13-2021, 02:33 PM
GTOGEORGE's Avatar
Glad to see proper safety equipment with the power of car!
GTO George
  #126
Old 04-13-2021, 02:47 PM
ErikW's Avatar
Default Transmission
So I built the 4L80E for Bandit. I used a billet overdrive planetary carrier, 300M input and main shafts, BTE aluminum direct drum w/36 element sprag and increased intermediate clutch capacity. Machined the front pump for a Extreme Automatics bellhousing adapter and added a Reid racing BOP bellhousing. We are using a CK performance transbrake valvebody which retains the ability to be automatically shifted by the computer. (Holley Dominator). Along with some super secret mods Nick and I are experimenting with. Should be able to handle up to 1500 HP. We also have a trans shield for this bad boy.
ID:	564635   Click image for larger version
ID:	564636   Click image for larger version
ID:	564637   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #127
Old 04-13-2021, 02:52 PM
ErikW's Avatar
GTO George
Safety is first with this build. Full fire system being installed also. Chassis certified to 6.00 even though we don't plan on ET's that low.
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #128
Old 04-13-2021, 03:04 PM
ErikW's Avatar
Default Cowl fix
I was just going to let this go and use a monsterous stack of shims for the fender but my concience got the best of me. Ordered a new cowl top and sectioned in what I needed. This car was hit pretty hard in the right front at some point in it's life and the fender pushed the cowl down right there. Tried to heat it and slide hammer it back up to no avail.
ID:	564639   Click image for larger version
ID:	564640   Click image for larger version
ID:	564641   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #129
Old 04-13-2021, 03:15 PM
ErikW's Avatar
Default Primer party
So after quarter panel replacement, cowl repair, firewall smoothing, roll cage and chassis mods it was time to get this thing in epoxy primer. I know it should have been done right after media blasting so don't shoot me. Gathered up family and friends and armed everyone with sand paper, scotch brite and wire wheels and about 5 hours later it was back to surface rust free bare metal. Shot everything with black epoxy. Then with my favorite undercar paint, Rustoleum semi-gloss black thinned 4:1 with acetone.
ID:	564643   Click image for larger version
ID:	564644   Click image for larger version
ID:	564645   Click image for larger version
ID:	564646   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #130
Old 04-13-2021, 03:23 PM
ErikW's Avatar
Default Gold Cage?
One of Nick's buddies suggested we paint the cage gold to go with the Black and gold Bandit theme. At first I thought he was crazy but after a test spray I think it's going to look awesome. We'll use the same color on the steering wheel and other accents in the interior.
ID:	564648   Click image for larger version
ID:	564649   Click image for larger version
ID:	564650   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #131
Old 04-13-2021, 08:58 PM
AIR RAM AIR RAM is offline
Amazing work man!!! Just WOW!
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
  #132
Old 04-13-2021, 11:04 PM
quick67bird's Avatar
quick67bird quick67bird is offline
Nice work guys. I can’t wait to see it run.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
  #133
Old 04-28-2021, 07:39 AM
ErikW's Avatar
Default More Progress
Some final assembly and more mock up pics. Nick carved up some drive pulleys for the alternator and vacuum pump out of a 6" billet of aluminum on the lathe. Then fabbed brackets for them. I got the brakes plumbed and bled. Got to have wipers for drag week so we got a lightweight Newport Engineering wiper motor and installed that. I got Nick a Kirkey containment seat instead of the regular drag seat so he had to do a little tweaking of his original mounts for that but I'll feel better knowing he's safer. Started some final assembly of suspension components. More to come.
ID:	565558   Click image for larger version
ID:	565559   Click image for larger version
ID:	565560   Click image for larger version
ID:	565561   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #134
Old 04-28-2021, 07:43 AM
ErikW's Avatar
More pics. Also made a bracket for the Holley digital display so the dash can be removed and the display remains in place.
ID:	565563   Click image for larger version
ID:	565564   Click image for larger version
ID:	565565   Click image for larger version
ID:	565566   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #135
Old 04-28-2021, 09:26 AM
ErikW's Avatar
Don't know why all of the pics uploaded sideways. I'll try to fix them tonight
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #136
Old 05-15-2021, 07:04 AM
ErikW's Avatar
Default Intake Fabrication
So, Nick got started on the intake manifold. The intake began life as a Kauffman sheet metal tunnel ram. We are using a 105mm Wilson throttle body so the two had to be mated and remain under the hood. First Nick cut off and squared up the ends of the plenum, then mocked up the throttle body where we wanted it and started to build to it.
ID:	566602   Click image for larger version
ID:	566603   Click image for larger version
ID:	566604   Click image for larger version
ID:	566605   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #137
Old 05-15-2021, 07:07 AM
ErikW's Avatar
This sideways pic upload is really getting annoying! Don't know what's up with that.
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #138
Old 05-15-2021, 07:16 AM
ErikW's Avatar
Default Intake
Nick machined a mounting flange to build to then set to work.
ID:	566608   Click image for larger version
ID:	566609   Click image for larger version
ID:	566610   Click image for larger version
ID:	566611   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #139
Old 05-15-2021, 07:19 AM
ErikW's Avatar
Default Intake
More building then a test fit to make sure she'll clear the hood.
ID:	566613   Click image for larger version
ID:	566614   Click image for larger version
ID:	566615   Click image for larger version
ID:	566616   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #140
Old 05-15-2021, 07:29 AM
Nice work!
How did you hold the camera with the last pic, looking through the hood?
Use that orientation?
(looks like hold camera 90º rotated to the right from normal way)
