Old 11-13-2017, 10:46 PM
RA1John RA1John is offline
Default Muncie Trans I.D. Tag
Anyone have a 67-69 Firebird with it's original Muncie trans. that still has the factory I.D. tag attached to one of the side cover bolts?
I'm curious as to what number is on these tags...
Factory assembly part number, as found in PMD Parts Catalog
or...
See pix below for reference.
Note that the tag below (from a '69 T/A) matches what is in the parts book.
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
Old 11-13-2017, 11:17 PM
Jason Rogers Jason Rogers is offline
I have the original muncie for my 67. It has the vin stamped in the top case. I have never seen that tag.
Sent from my SM-G860P using Tapatalk
Old 11-14-2017, 02:02 PM
silverbullet07 silverbullet07 is offline
I have the original and mine has the tag. I will have to get a picture of it and post it.
Old 11-16-2017, 12:58 PM
John V. John V. is offline
John, it should be the original trans assembly p/n.
My '64 GTO M20 trans still has the 9774825 p/n tag attached to the side cover.
If you ordered 3.90 axle in '64, you got the 9774826 trans assembly (same M20 trans but with a 6 tooth internal speedo drive gear for speedo accuracy with the 3.90 axle).
Late year '64, you could order the M21 as a Special Equipment Option, the trans assembly p/n on the tag was 9777000.
None of these p/ns would be found in the '66 Master Parts Catalog since they were all superseded by the '65 p/ns.
So you need to be careful looking at the MPC Service Replacement p/ns. They may or may not be the same trans assembly p/ns used in production, just depended on whether the original production trans assembly p/n had been superseded by the time the MPC was issued.
But I'm 95% sure that the original tags on '67-'69 Muncies would show the trans assembly p/n, same as was being done in '64 and '65. And same as you found for that tag for the TA (same style as the tag on my '64).
The p/n tag was installed by Muncie when they assembled the trans before shipping to the various Final Assembly Plants. The VIN stamps were done at the Final Assembly Plants, Muncie had no idea what specific build a given trans assembly would be installed in when they shipped the trannies.
I don't know much about the Firebird. Looking at the MPC excerpts you posted, I'm curious to know how the Muncies used in the 'bird differed from the Muncies used in the Tempest which warranted unique p/ns for each.
Only thing I can think of might be a difference in the internal speedo drive gear due to a tire size difference. Or did the Firebird require a different tailhousing vs. the Tempest? I would have expected them to carry the same p/ns, so I'm surprised that they didn't.
Old 11-16-2017, 04:00 PM
MikeNoun's Avatar
MikeNoun MikeNoun is offline
Here's a cool one. Brian Styles recently located this for his 1968 RAII Firebird.
Old 11-16-2017, 07:47 PM
It appears I have my correct tag 9792530.
Old 11-17-2017, 04:03 PM
What would be the correct number for a 1967 firebird 400 with a.i.r, 3:36 posi, muncie?
Old 11-17-2017, 07:47 PM
A Schab A Schab is offline
John V, I believe that Firebird part numbers are not the same as A body’s because the speedometer cable drive locations are on opposite sides of the tail housing.
Old 11-17-2017, 08:54 PM
A Schab, that would make perfect sense (as far as the p/n difference). Perhaps the Camaro influence forced that? Pontiac generally used the LH location, Chevy the RH from what I've always understood, at least for a time.
Jason, I can only go by what John posted from the MPC.
If there was no supercedure, all '67 Firebird V8s would have gotten the 9789170 unless equipped with a 3.90 or 4.33 rear axle.
If you have an original p/n tag on yours, would be worth knowing what it reads.
I think the p/n tags are reproduced, aren't they? Or is that a Corvette thing?
Old 11-18-2017, 04:25 PM
Ron Landis's Avatar
Cool So...
I have several original tags...even one with a WT suffix...and have decoded them all but I do not believe I have any numbers mentioned here. I'll try to get some pix up.
Old 02-07-2021, 06:56 PM
DANTIP DANTIP is offline
or...
Here's what I have been told is an untouched 40,000 miles M20 from a '67 400 Firebird.
Name:	Screen Shot 2021-02-07 at 5.32.20 PM.jpg
ID:	560332   Click image for larger version
Name:	Screen Shot 2021-02-07 at 5.32.32 PM.jpg
ID:	560333   Click image for larger version
Name:	Screen Shot 2021-02-07 at 5.32.55 PM.jpg
ID:	560334   Click image for larger version
Name:	Screen Shot 2021-02-07 at 5.31.59 PM.jpg
Old 02-11-2021, 03:04 AM
turbo69bird's Avatar
Is that the same number for my RAIv car w 3.90 ?
960 HP @ 11 psi, 9.70 at 146.
Old 02-11-2021, 05:23 PM
The tag # on my R/A IV 69 T/A with 3.90’s and m 21 is 9798975. I believe it is original to the car.
Old 02-12-2021, 03:50 AM
Thank you.
Thread Tools
Display Modes
