Installing 69 Firebird rear marker lamps on a 67 firebird.
I need help from my 69 firebird experts. I am trying to install the 69 rear marker lamps on a 67 firebird. I need a template so I can cut the quarter panel correctly. A paper template, a scrap piece of the rear quarter panel, anything that would help me make the right cut, and position the cut appropriately. Please help!! 😎
Pure Pontiac Power!!! Picture of my actual 69 Judge racing in 1970. Rare Espresso Brown Ram Air III, 4 speed, manual steering with power disc brakes and factory build sheet indicating 4:88 special order rear axle. |
On 69s there's a fender crease that 67s don't have. Lamp is below it. You'll have to decide where you want it.
Thanks for the quick response. I understand there is a fender crease, I just want to cut the opening for the lamp correctly, and place the lamp appropriately dimension wise with the 69 model.
Can't you just trace the inside of the lamp gasket on a stiff piece of construction paper, then transfer it to the fender?
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman |
It’s possible. I just ordered the marker lamp assemblys. Until I see what I am working with, it is a shot in the dark. I only get one shot to cut the quarter panels correct.
I bought my 69 in 1995 and it had replacement qtr panels on it without the cut-outs (they are not Camaro qtrs). Anyway- I traced the pattern from someone else's bird as indicated here but have yet to make the cuts for fear of making a mess - figured I'd wait for when it's time to repaint. How are you intending to cut yours and is the car already painted?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project Last edited by grivera; 02-02-2021 at 10:35 AM. |
I intend to do a center hole cut, then slowly use a dremel tool to cut the rest. My car is currently painted, but I plan on doing a repaint soon. Do you still have the template you used off the friends car?
I have it in storage somewhere - will look for it this weekend (working long hours till then)
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
Thanks 😎
Here is a PDF 8.5x11” paper - it’s not as sharp as I hoped
https://dc-api.adobecontent.io/16133...ZEcEIrR1lxZz09
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project Last edited by grivera; 02-07-2021 at 07:26 PM. |
Send me your email and I’ll send pdf to you
