Old 05-04-2021, 11:30 AM
68lemans462's Avatar
68lemans462 68lemans462 is offline
Default 68 Lemans no brake lights
I have verified the following:
12v on both sides of "STOP" fuse
12 v on both sides of brake switch. Switch is working fine.
turn signals work both sides
running lights work both sides
Cannot get brake lamps to turn on at all
The car has had a bum turn signal switch for decades. I have to hold down the turn signal lever, it does not hold itself in place or switch off when the wheel is turned. When looking at a troubleshooting procedure in the manual, I see "defective directional signal switch" and "improperly adjusted switch". I believe this is the next place I need to go. I seem to remember the 68 non-tilt turn signal switch to be an oddball and no replacements available as of a long time ago. I'm now seeing some switches available on e-rape... Where does a guy go from here? thanks
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 05-04-2021, 12:22 PM
Just checked the wire harness at the steering column. I have power at the dark green wire, but yellow shows no voltage. Looks like it might be time to look at the signal switch...
Old 05-04-2021, 03:48 PM
steve v's Avatar
steve v steve v is offline
Check to make sure the 4 way flasher switch is in the off (pulled out) position. I have seen some in the past that had the switch pushed in and the 4 way flasher was removed resulting in no brake lights. HTH
