A google search may unearth this procedure and save you the time and gaskets. I did NOT download this - try at your own risk. https://onlinerepairmanuals.com/work...manual/5529975 Last edited by Scarebird; 11-18-2023 at 07:27 PM. |
The Following User Says Thank You to Scarebird For This Useful Post: | ||
I have ample amounts of fuel, a new carb, an HEI that's producing spark, and it's been set with #1 TDC multiple times. I'm getting nothing. Not a cough, backfire, pop, nothing. It's like it doesn't have ignition, despite having spark. The only thing I can think of is the valve timing is off.
Well, take a look at this BS. Timing mark on crank facing 12 o'clock, cam is drifting off somewhere around 2.
Numb nuts put this together
That would do it.
Where's the dot on the crank gear? I see a white line but not the dot.
But that is way if it is where the line is. Did you put the white lines on?
I put the lines on so they're easier to see in the pics.
So I removed the crank sprocket and installed it straight up (not advanced or retarded) and spun the cam until the dot on it lined up the the crank sprocket, and re-installed the chain. Now I got the dots facing 6 o'clock on the cam, and 12 on the crank. After rotating it 360° they line back up and cylinder #1 is at TDC.
Sounds right, right?
The highlighted mark on the crank sprocket is a stamped square?
I think they're asking if you know which key slot and mark are correct for "straight up". Is a square mark for "0" advance? Or is it a round mark, triangle, whatever...
I just bumped the key and got it to cough through the carb slightly, which is more than I was ever getting before. So I'm definitely on the right track
Exactly.
Circle = Straight up Triangle = 2° advanced Square = 2° retarded per Cloyes |
I have no idea wtf happened during installation. I guess I'll go over everything to make sure nothing else is installed incorrectly.
Wow, if the square mark was under your white paint, then you definitely found the smoking gun.
Caca happens, but this one sounds beyond frustrating. Good job figuring it out. |
Well, it's all back together. Just waiting on some gaskets. Did a little test fire and got it to go. So I guess the previous owner just messed up the chain installation.
Got the car up and running! Had to wait a few days for parts and such, but got it fired up, broken in for 20 minutes at 2000-2500 rpm, and locked in the timing where it seemed to like it.
What are you guys doing oil wise after break in? I have always changed break in oil the day after initial start and set up, and run Dello with a zinc additive on top of it after.
The Following User Says Thank You to 72projectbird For This Useful Post: | ||
Good to hear.
Next up, interior. Already have the seats redone with new foam and covers, just waiting on the headliner before I install everything. Also building a 4 relay system for the power windows, instead of using the stock setup that runs the power thru the switch before going to the motors.
#38
Got the 4 relays installed for the power windows, and Jesus they're fast now. Bypassing the factory relay that ran all the power through the switch, and instead having a dedicated relay for each up and down function per window really helped. More than I figured it would. The windows are lightning quick now. Pretty sweet.
Just got the headliner delivered today. Hope to start assembling the interior this weekend.
#39
I need need to purchase and install a headliner in my son’s 79…any tips? Has to be easier than an early car with the bows…
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
#40
It was easy, I did my 78.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes F ire B irds 🇮🇱 |
