Harlan Sharp roller rockers ID ?
I cannot seem to find any markings on the gold roller rockers I have . Said to be H/Sharp . Also how to check the ratio of them ? Thanks .
I have never seen Sharps that are Gold, there more Orange!
Go to there web site and check it out.
I think I have a set of gold ones too and don't remember a name on them, I'll check and report back.
The More People I Meet, The More I Love My Dogs! |
Mine are orangey gold. Mine are 1.5, but don't know how to tell the difference.
Ok , I have to admit that I am color blind . I do know that they are not red or blue. They are maybe like the orange gold.
Post up a picture , many of us here are not color blind, lol!
To check the ratio you have to set them up on one cylinder, have a way to measure the lift and also know what the Cams lobe lift is. .270 factory lobe lift with a 1.5 rocker would give you .406" lift at the valve at least by the math!
Comp Cams makes gold ones
The 1.65's pushrod cup gets into the fulcrum area slightly. The 1.5's do not
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
Here's a picture of my 1.65 Harlan Sharp rockers. 1.65 is marked on them, but I don't have a picture that shows it.
I've got pictures here of 1.5s vs 1.65s. Flip them upside down and look at pushrod cup. If there is a slight cut into the curve in the body for the trunnion it is a 1.65. !/5s cup is out and does not shave the curve area. Mine sets do not have any marking on them but once you look easy to tell. Same deal on stamped steel rockers also.
I have never had H&Ss that were marked.Tom
Bober -
Post up a pic of one of those rockers where the push rod sits. Several of us could tell you if they are HS and the ratio. We like to play that game. Hah!
- Tom |
Crane rockers are gold also.
I think the HS on the right is a 1.5
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" Last edited by Old Goat Racer; 07-26-2017 at 04:47 PM. |
The one on the right is a 1.5.Tom
BTW: I have run the same set of HS roller rockers on several motors including the current race motor. Tens of thousands of street miles and thousands of passes at the track. Great product. Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
Harland Sharp has great customer service..they rebuilt my rockers and returned them in under 2 weeks.This how they returned.
I understand that the pushrod is close to the fulcrum on the 1.65 because I've seen both side-by-side. But if you have never seen one of these rocker arms, how would you know "how close is close". I have seen a picture of these side-by-side. I thought the OP might benefit from that.
- Tom |
http://www.harlandsharp.com/ratios.html
Here you go. A Picture of Harland Sharp rockers for Pontiac side-by-side showing what different ratios look like.
- Tom |
I'll look on my other computer and see if I still have the picture somewhere or pull them out of the attic and take a new one.
OK , If they're 1.65 rockers how much trouble and cost to go w/1.65 rockers ? I would need diff P/rods and what else ?
