Headers on 72 column shift LeMans?
Does anyone know of a header that will fit and work with the column shift like on a 72 LeMans? I was thinking those 3 tube headers would work but they won't according to Hedman. I know I could use the Ram Air manifolds but this is a low$$ and low power 350 project. Thanks, John
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
https://www.summitracing.com/parts/b...c/model/lemans
These fit my column shift car well |
Johnny406, any update? I have a 72 lemans 350 column shift 3 speed as well. Cruiser to weekday events. Not a show car. Needs all new exhaust and I’m thinking headers as well.
1972 LeMans' $41 Nose Job - Father Son Project Car 350 4bbl 3.55 Richmond Gears w/ Auburn Posi |
Buy any header that suits your needs. Buy the $50 dollar kit from shiftworks and its a plug and play deal. I used this on my 72 455ho column shift, car. No issues. Took all of 20 minutes to put on once the headers were installed. The gear selector lines up, reverse lights work, and no issues to speak of.
1970 Formula 400 4 speed 2006 Gto. Ls2/m6 1972 Gto 455ho/th400 post coupe 1973 Grand Am 400 4 speed |
Thanks for the response and great information on that linkage that takes guess work out of CHOOSING a set of headers.
Any advice on headers that fit well? Doubt I’ll see or feel much gain on a basically stock 350 4bbl build with the ram air style cam that summit sells for $100. But I’m just kicking around the idea for budget headers for bolt-up reasons to what will be a larger-than-stock full exhaust system that needs to go on this spring. I think I’m at 1-7/8” exhaust up to (2) blown-out-the-bottom Walker mufflers to 2-1/2” tailpipes currently. Thanks again for any suggestions.
i will never install tube headers on another street pontiac. The RA manifolds are awesome. I used Hooker comps (or super comps i dont remember.) Car needs to be at least 36" off the ground for install. Oil filter needs to be moved/modified a little bit. Future oil changes will be messy. Brake proportioning valve needed to be moved a bit. Passenger side header sits VERY low, and sometimes hit the ground. Header bolts were difficult to tighten. Had to bend several small wrenches just for the install; and to maintain. Header bolts needed to be checked often for tension. Gaskets blew a few times. ...And with my stock 400 and 3.08 gears there was no benefit at all. i actually lost low RPM power. You've got 3.55 gears; so you may get some small gain; but for me, it still wouldnt be worth the trouble. I bought the RA manifolds and never looked back. They never come loose, never hit the ground, never leak, fit perfectly, and i got some of the low RPM torque back, that I'd lost with my tube headers and my rear gear. Worth the extra money. Just my opinion and my own experience. 71 GTO. |
... I eventually removed my headers with a sawzall.
that part was torture too. |
Headers are not needed for a stock type motor, they do however have their place with higher Hp motors. I have RA manifolds on my '72 LeMans with a 415 Hp 455, but I will be using headers in my '68 FB after I put the 650 Hp motor in.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
