Old 09-03-2003, 11:54 AM
1966 goat 1966 goat is offline
Does anyone know how to check if a sender is still good. Do you need to run current through it?
Old 09-03-2003, 01:10 PM
george kujanski's Avatar
On a '67, if you disconnect the wire from the fuel tank and measure the resistance of the tank sender to ground, a full tank will read about 90 ohms and an empty one about zero (or low).
Regards, George
