Old 05-12-2005, 04:22 PM
senn66gto senn66gto is offline
I need help with locations of engine #'s and and matching what. How do I determine if the engine is the original engine? Any help would be appreciated
Old 05-12-2005, 05:07 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
Left hand side of the block, pass side as you look at it from the front.
There will be a two diget code, probably both letters.
Then a sting of numbers. If you have your Protecto-plate or your PHS documents, that number will be on them. Cyl heads should be 093 or 670 if a 1967 car.
www.phs-online.com If you don't have the PHS on it, I suggest you get it.
Old 05-12-2005, 06:31 PM
Tripower455's Avatar
If you don't have the protectoplate, then you have to go by casting date, which should be a few weeks (or more) before the car was assembled.
They started putting the VIN number on the block in late '67, IIRC, and certainly by '68.
The casting date is located by the distributor hole, and will consist of a letter, which indicates the month, then 3 numbers, indicating the day and the last digit of the year.
My 455 is a '74, so the date code reads I283, which is September 28th, 1973.
A '66 or earlier car with a proper casting number, 2 letter application code (ie: YS for an auto) block, intake and heads date coded a few weeks or so before the assembly date of the car, is generally considered "numbers matching". YMMV......
Old 05-12-2005, 06:55 PM
3 Deuce 64's Avatar
3 Deuce 64 3 Deuce 64 is offline
Send a message via AIM to 3 Deuce 64
there is also a part number cast in the side of the block
Year CID Casting Number
1964 389 9773155
1965 389 9778789
1966 389 9778789
1967 400 9786133
1968 400 9790071
1968 400 9792506
1969 400 9790071
1969 400 9792506
1969 400 9792968
1969 400 545887
1970 400 9799914
1970 400 9799915
1970 400 481708
1970 455 9799140
1971 400 481988
1971 455 483677
1971 455 485428
1972 400 481988
1972 455 485428
1973 400 481988
1973 455 485428
1973 455 490132
1974 350 488986
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves." Abraham Lincoln
"A free people ought not only to be armed and disciplined, but
they should have sufficient arms and ammunition to maintain a
status of independence from any who might attempt to abuse them,
which would include their own government." — George Washington
