Old 08-10-2001, 10:51 PM
69RAGSTER 69RAGSTER is offline
What would remove buffer burn marks from a paint job?
Old 08-10-2001, 11:49 PM
MitchGM's Avatar
MitchGM MitchGM is offline
Depends how far down you went, and what kind of paint you have. It's possible to compound out some marks if they aren't too far down to the primer.
"Life is what happens to you while you're busy making other plans."
"More tears are shed from answered prayers, than unanswered prayers"
Old 08-11-2001, 07:59 AM
jim darlington jim darlington is offline
Tell us more about the paint . Is it a fresh basecoat/clearcoat paint job , or are you buffing out old paint to make it shine . If it's new clearcoat job . All you have to do is wet sand the area with 1200-1500 and buff . Are you sure it's not a smudge mark left behind because your pad was dirty . If so ,soap and water , and a little glaze will do the trick .
Burn marks in old paint , especially single stage paint , well there's not to much you can do to repair them .
Remember while buffing always keep the pad clean , keep it moving , stay away from edges , and run the correct RPM for what you are doing .
Man is not complete until he's married , then he is finished !
Old 08-11-2001, 03:24 PM
It's older paint with clear coat. I've been able to get a little out with cut type waxes.
