Old 07-16-2022, 01:26 PM
SD455DJ SD455DJ is offline
Default Cool ’65 396 4-speed Chevy Belair
I know this isn’t a Pontiac, but it’s too cool not to share as I think most Pontiac lovers will enjoy seeing this. Scott is doing a quick once-over of a 1965 Chevy Belair that hasn’t been on the road since 1972. What makes it really unique is it is owned by the original owner’s brother, who has owned it since 1967…and it’s a factory original 396 (325 hp L-35), M20 4-speed, 3.31 posi 12-bolt, (manual steering & drum brakes!), in its original dark blue (Fathom?) paint and light metallic blue Belair trim interior with the factory in-dash tach and AM radio. The brothers installed ’65 bucket seats a long time ago and tossed the original bench seat out. It has 59,600 miles and was pulled out of a barn (yes, another true barn-car) and was trailered to a local car show for display, where Scott saw the car and met the owner, and subsequently talked into giving it the thorough inspection before it goes back on the road.
Dennis
ID:	594426   Click image for larger version
ID:	594427   Click image for larger version
ID:	594428   Click image for larger version
ID:	594429   Click image for larger version
The Following 4 Users Say Thank You to SD455DJ For This Useful Post:
Old 07-16-2022, 01:46 PM
So much awesome right there.
One of the few out there optioned up like a muscle car and so untouched, really who wouldn’t love to own that beautiful car.
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 07-16-2022, 01:51 PM
67drake's Avatar
67drake 67drake is offline
I’d buy that.
13.95 @ 102.1 on street tires @ 4055lbs.
Old 07-16-2022, 02:25 PM
77 TRASHCAN's Avatar
My first car was a 67 Bel Air, 283/glide/hubcaps...LOL 4 door. bought in 1975 when my family still lived in Iowa
I was fortunate to live in a town in S.E. Oklahoma that had a legit engine builder/drag racer. He is a Chevy guy. He built my 283, dyno'd it. He also built a lockup TH350 that easily took the place of the glide. I obtained a 12 diff from a 69 Impala, found a 2 series posi for it. He set up the rear end for me with 2.73:1 gears (too tall for a 283, but worked out)
I have a lot of knowledge of those cars. The 65-70's were the same platform.
I converted mine to power disc, power steering. added a larger front sway bar and added a rear sway bar.
I had it repainted stock color in 1978. In 1997 the body and frame were rusting away, again. I parted it out. Gave the suspension parts to a friend with a 65 Impala. Kept the engine, trans, rear end....
Shut it off
Shut it off
Old 07-16-2022, 02:49 PM
This '65 Belair is pretty nice, but a little crusty around the edges, like the bottom rears of the rear quarter wheel openings have minor rust-through, but only there. The floors (trunk & interior) are solid as are the lower front fenders. The deck lid's rear lower seam is splitting due to a huge mouse nest across the width, but it looked relatively fresh, so not a ton of mouse poop & pee to remove and didn't rust it through as it would have after a couple years of habitation. We're worried there is a mouse house up in the headliner as there is a small hole over the drivers seat, but we don't see 'lumps' in the surface. Hopefully, they didn't have time enough to really get settled in to cause more damage. All the stuffing the little buggers used appear to be from the seats.
It's a very honest original car and is going to be preserved in it's current original state...other than going through the brakes, suspension, and wiring to make it safe to drive again after being of the roads for 50 years!
Dennis
ID:	594436   Click image for larger version
ID:	594437   Click image for larger version
ID:	594438   Click image for larger version
ID:	594439   Click image for larger version
Old 07-16-2022, 04:31 PM
70L34 70L34 is offline
Beautiful car. One of the best colors for '65.
Old 07-16-2022, 05:21 PM
Tom Vaught's Avatar
Boost Engineer
Picture #3 even has the famous flying engine retention strap!!!!!!!!!!!!!!!
That is a very cool car.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
Old 07-16-2022, 05:44 PM
CDN2PLS2 CDN2PLS2 is offline
How about the GTO under the Tree??
Old 07-16-2022, 07:13 PM
It’s here, a barn find, search Dennis’ threads, another very cool story/car!!
Shut it off
Shut it off
Old 07-16-2022, 07:29 PM
Thanks,I missed that.I was wondering when they were going to tell the story.Still should go to MCACN tho.
Old 07-16-2022, 09:37 PM
400 4spd.'s Avatar
Tom V.
I remember my father’s 1969 Impala being recalled for that cable to be installed. I recently had a survivor 69 SS Camaro in the shop with the cable intact. My 40 y.o. mechanic/employee was stunned when I explained what it was for.
Old 07-16-2022, 09:44 PM
carcrazy carcrazy is offline
Always loved the 65 Impala/Biscayne/BelAir 4 speed cars. Growing up one friend had a 327 4 speed Belair and another had a 65 Impala SS, 396 4 speed. Both were daily drivers but could run hard at the track.
Old 07-16-2022, 10:32 PM
61-63's Avatar
61-63 61-63 is offline
I'd buy it too!
Old 07-16-2022, 10:37 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
Originally Posted by 61-63 View Post
I'd buy it too!
X3, I'd stuff that bench seat back in there as well.
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
The Following User Says Thank You to 4zpeed For This Useful Post:
Old 07-17-2022, 05:40 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Very cool car! Thanks for sharing!
Old 07-17-2022, 07:42 AM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
Very cool!
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of!
Old 07-17-2022, 07:50 AM
thepontiacman's Avatar
thepontiacman thepontiacman is online now
Very cool.
I once saw a 65 Biscayne 4 door dark blue with 396/425hp 4 spd in floor from the factory. Sleeper that someone ordered.
Always cool to see something different.
Sent from my Moto Z3 Play using Tapatalk
Old 07-17-2022, 07:52 AM
5th TA 5th TA is offline
What a great time capsule, glad it is being preserved. It’s hard to believe these great barn finds keep popping up.
In 1970, while still in high school I worked part time at a transmission shop. I replaced a lot of motor mounts on 65-70 Chevy’s. I can remember several times cars were towed in because they were dangerous. Under the right conditions cars with automatics could be started while in gear, even though the shift quadrant indicated it was in park. The engine could torque over because of the broken left mount, as the engine torqued the design of the throttle linkage would raise the engine rpm and sometimes simultaneously pull the vacuum line out of the power brake booster. Causing the car to leap forward with just the turn of a key. I personally witnessed this phenomenon twice, Very alarming the first time it happens because the car takes off with reduced braking ability. Fortunately the shop owners had a rule, to always start cars with one foot on the brake. My apologies for hijacking this thread.
The Following User Says Thank You to 5th TA For This Useful Post:
Old 07-17-2022, 08:09 AM
Aaron65's Avatar
Aaron65 Aaron65 is offline
It's been said a bunch already, but that is a super cool car...I love it! For some reason, I've been dreaming about a '62 Bel Air 2-door post lately, even with a 283 or something.
1974 Firebird Esprit
1953 Buick Special Riviera
1963 Riviera
1963 Thunderbird
1965 Mustang
1965 Skylark Sport Coupe
1965 Dart 170 Wagon
1965 Corvair Monza Convertible
Old 07-17-2022, 08:30 AM
sp4spd's Avatar
sp4spd sp4spd is offline
Very cool find Dennis!
My first car was a 65 Impala SS 396 4 speed, same color combo!
Had to sell it just after high school to pay for further schooling.
Brings back some fun memories!
Biggest problem with that car was the 4 wheel drum brakes..... Did the brake fade boogie quite a few times while showing off in front of the high school!
Scott
74 Firebird Formula 400 4speed
70 Buick GS455 4 speed
