Old 01-22-2023, 08:20 AM
It is 462 CID
The stock 455 piston is 4.181 so .030" overbore is 4.21" bore.
Stock stroke is 4.21"
Old 01-22-2023, 08:24 AM
Skidmark Skidmark is offline
It is 462 CID
Thanks,
Any idea of approx HP / torque? Has a cliff built Qj. Stock intake. Factory exhaust manifolds.
Old 01-22-2023, 08:31 AM
25stevem's Avatar
25stevem 25stevem is offline
A motor can not make any torque or hp without a Cam in it hint….hint!
Is what you posted what you are keeping in the motor, because it’s kinda small for a 462 even with basically stock heads.
I do stuff for reasons.
Old 01-22-2023, 08:42 AM
Yeah, for now. Engine runs good for a cruiser. I don't race. After I paint the car, I might change the cam.
I know from being on this forum for awhile, that many don't care for the xe268H.
Would a 068 cam be better?
Old 01-22-2023, 09:17 AM
25stevem's Avatar
No, that XE is still a far better pick for your CID motor then the 068.
I hope that the heads you are running are set up with springs and clearances other then stock, because that cams lift would have stock parts at there very liming or over!
Anyway with stock heads even that Cam is done by 5200, and with stock rods you go not want to go above 5500 anyway so you have a far lesser chance of blowing the motor up.
If your happy with its street manors now and with it making between 380 and 400 Hp then that’s all that matters !
Old 01-22-2023, 09:48 AM
All I know about the springs and clearances is what was on the receipt, but hey if you think I'd be between 380-400 HP, then I'm very happy.
I know the 1972 YS engine was rated @250 from the factory.
Old 01-22-2023, 09:56 AM
Here are the springs
Old 01-22-2023, 01:59 PM
What car is the engine running in ?
You can tell them you have a bored and stroked 400 (sounds exotic)
or a Squared 455 with equal bore & stroke (sounds like advance level engineering)
or a 462
Or throw all of that out in one sentence .
Old 01-22-2023, 03:06 PM
or a 462
I like it! Makes it sound special to the untrained ear.
I pulled it out of a 72 grandprix and now it is in my 72 lemans sport.
The Following User Says Thank You to Skidmark For This Useful Post:
Old 01-22-2023, 04:52 PM
grandam1979 grandam1979 is offline
It is 462 CID
Unless I’m reading this incorrectly none of this is correct? 4.181 is .030 over for a 455 .060 for a 400 block. 4.211 is .060 over 455 and would be .090 over for a 400 block.
Old 01-22-2023, 05:23 PM
Originally Posted by grandam1979 View Post
Unless I’m reading this incorrectly none of this correct? 4.181 is .030 over for a 455 .060 for a 400 block. 4.211 is .060 over 455 and would be .090 over for a 400 block.
You're right. Per Butlers website.
400 bored .060 over is 4.181
455 bored .030 over is also 4.181
Old 01-22-2023, 05:34 PM
Yes, I wrote the bore size wrong, it would be .030" over (455) which is 4.181.
But the CID is still correct at 462.
It would need 455 pistons because of the pin ht. and the rod length.
Old 01-22-2023, 05:36 PM
Thanks John
Old 01-22-2023, 05:48 PM
Does anyone know approx HP and torque would be? One member thought 380-400 HP he didn't mention how much torque. My car will never see a Dyno, so I ask here.
One more time:
1972 YS 400 bored ..060, 455 crank conversion to fit 400 block, now 462 cid, 7k3 heads stock, comp cam xe268H, cliff QJ, factory exhaust manifolds
Factory intake
Dual exhaust
ID:	605770   Click image for larger version
ID:	605771   Click image for larger version
Old 01-22-2023, 06:59 PM
Dragncar Dragncar is offline
Its a 455 with a decent sized cam, nice q jet on our fine factory intake.
Its going to make the 380-400 HP as easy as falling out of a tree and be near 500 ft lbs.
I would find some Ram Air/HO manifolds or 1 3/4" headers and run it.
Should be a very fun to drive, push you back in your seat kind of ride.
Old 01-22-2023, 07:16 PM
tom s tom s is online now
My 455 with SP II cam and dead stock 48s made I think close to 450.The build was on this site.Tom
Old 01-22-2023, 07:31 PM
Thank you,
Exactly the kind of info I was looking for. I have wanted a pair of those ram air/HO manifolds. They're in my future for sure.
  #38
Old 01-24-2023, 03:37 PM
Wondering if I have posted enough info about my engine to tell me what the compression ratio is. It will not run good on anything less than 93 octane.
I've read XE cam might be the problem.
Old 01-24-2023, 04:02 PM
Matt Meaney's Avatar
Matt Meaney Matt Meaney is offline
a ballpark on the compression would be about 9.25:1, could go a little one way or the other depending on specifics.
i had basically that same engine a long time ago in my daily. it had a 041 cam with 1.5.2 rockers. nice heavy idle sound at 750 rpm in gear and great drivability.
“We don’t build a ‘luxury’ car. We build a performance car then we make it luxurious.”
  #40
Old 01-24-2023, 09:08 PM
Matt, thanks man.
