Roof cracking?
have the 70-73 models been prone to roof cracking? i know the later t-tops and possibly the wrap around rear glass on 75 and up.
I see tiny cracks in the paint on both rigth at the top corner above the passenger and driver chrome vindow trim.
Murphy's law - "Anything that can go wrong will go wrong". -469 ,Butler 310+ Eheads, Hurricane intake portmatched by butler, Butler roller 230/236 @0.50 112 LSA, Johnson lifters, pypes 2 1/2" exhaust, 3.42 yukon duragrip lsd, holley sniper efi, hyperfuel efi tank +++ |
Rear corner of door opening? Body flex due to lack of full chassis.
yes, the top rear corner of each door, a tiny vertical line towards the rear window and horizontal line up to the roof on both sides, about 1/2 inch in size (for now) i guess i should get some subframe connectors in place. observed this shortly after upgrading the motor with a topend kit.
cracks here and accounted for/
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
The Following User Says Thank You to FrankieT/A For This Useful Post: | ||
these cracks are where the lead filler was put from the factory;
I think that more often than not the cracking described is because someone used body filler in this area.
Not at the corners.
A quick picture of drivers side.
The Following User Says Thank You to djustice For This Useful Post: | ||
Yes, a little embarrassed
I have seen these cracks bigger and smaller over the 45 years of having these cars.
Retention of moisture in that area can make this area worse for wear ( vinyl roof)
That said, you can put " Short strand" fiberglass filler in this area over lead that is still stuck to that seam where the roof overlaps the quarter. If lead has separated, there might be a gap under it and then led has to come off. I have re leaded these seams and I think there may be a substitute now. If its all stripped in that area, one could weld the panels together to make it less apt to happen. These were panel spotted when new IIRC. Starting in '73 at this area and bottom of A pillars, and rear tail pan/ bumpah mounting, the amperage of the welds was increased at Fisher Body to help meet the new 5 mph standards. This is one reason why '72 bodies were crushed and written off after the strike.
The Following User Says Thank You to Formulabruce For This Useful Post: | ||
BAM!! It happens again!! Thanks for sharing this!
The Following User Says Thank You to unruhjonny For This Useful Post: | ||
My ‘78 non T-Top Formula developed these cracks 4 years after car was built..
