Old 08-15-2021, 05:00 PM
rcush's Avatar
rcush rcush is offline
Default 67 GTO Rear trailing arm install
Do you tighten bolts in the air or with weight on rear end? Would think with weight but wanted to check first, Thanks!
Sent from my LM-Q710(FGN) using Tapatalk
Old 08-15-2021, 05:15 PM
thepontiacman's Avatar
With weight on suspension
Sent from my Moto Z3 Play using Tapatalk
Old 08-15-2021, 05:20 PM
rcush's Avatar
Thanks!
Old 08-24-2021, 01:14 PM
geeteeohguy's Avatar
With weight. All suspension parts, front AND rear. Otherwise you load the bushings in the wrong location and they twist and split.
Jeff
