Old 08-29-2021, 07:28 PM
Rob in NH's Avatar
Rob in NH Rob in NH is offline
Default carburetor problem
I had to change the top of my carburetor, took all the parts from the old one and put it on the replacement top. I did not set the float. It was rebuilt and figured that it would be ok. It started right up but now it doesn't have a smooth idle like before.
Was wondering if anyone had any advice as to what it could be? Its a Rochester
2 bbl.
Old 08-29-2021, 08:15 PM
Sport69 Sport69 is offline
Did you try tapping on the side of the carb the float is on with the handle of a screwdriver, maybe the float is sticking? Sometimes that works and sometimes not. If it smooths out then it's probably the float, or float setting.
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
Old 09-05-2021, 08:09 PM
So what did you figure out?
Old 09-05-2021, 08:25 PM
Rob in NH's Avatar
I repaired the threads in the original top and put it back on so its good for now but I plan on replacing it with an Edelbrock AVS2.
