E-head inserts
Anyone have pics or data on putting inserts in E-heads? Are they needed?
This would be aimed @ a stock runner head on a turbo appl. with ARP stud clamping deal. Thanks, KRIS
*** THE BIG BRACE is here *** |
Available in the archives if you search...
Sure...
I remember Charlie had issues & looked again over his past posts. Anyone else care to revisit? I would like to hear how much he torqued his stuff down. This looks all heat related on the outer/exh. flange side. I wonder what Remflex gaskets and added 421 cooling hole might do.. Anyone ever made convertible E-heads ? LOL Past posts for reference: http://forums.maxperformanceinc.com/...ghlight=insert http://forums.maxperformanceinc.com/...ghlight=insert
I've recently bought a set of Eheads for my turbo combo, I'm not fussy on the t-inserts or sleeves - you are machining away the ID of the bolt tower-weakening it- to fit the inserts.
My plan is to spot face the heads bolt pads and then use large diameter 1/4" thick hardened steel washers/ARP studs to spread the clamp load over a larger area -same as I did with my previous iron heads. |
I'm running a T washer on my turbo setup and did the "Charlie Mod Sleeves" on the two ends and center exhaust bolt holes. I had it originally converted with the T washer but I like his idea so I copied it.
It seems to be a consensus that excessive heat plays a big roll in the issue of bolt holes collapsing. Since learning about it, I have been looking at potential preventative steps I can take to help minimize or eliminate the chances of experiencing it personally.
Now I dont know if it will help or not however in theory, ceramic coating of the exhaust ports and combustion chambers should help prevent a good deal of heat transferring into the head in the first place perhaps minimizing or even eliminating the issue all together. Ive ceramic coated my E-heads to assist with street cooling my Turbo 496 (build in progress) . Perhaps Coatings teamed up with the above mod would further help... Just wondering what peoples thoughts are the possibility of coatings helping with the bolt hole collapsing issue? SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t" |
Would this mod help with the situation at all?
http://forums.maxperformanceinc.com/...55#post4689855 Running water through the head at the exhaust ports. Page 2 has good pics. I'm considering doing this mod on the Bandit's E-heads. Just not sure about the flow of things. As it is we will have the front and rear water ports run to a manifold then to the upper radiator hose. Similar to the pic attached. On this engine (pic) with Tiger heads, we tee'd the rear and middle holes together and joined the front water lines at the water manifold.
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT Last edited by ErikW; 01-30-2021 at 08:44 AM. |
Mine is reverse cooled and dry decked - so the cooled water goes directly through the heads rather than it being heated up by going through the block first.
The Pontiac heads have this ridiculous extra long exhaust runner and when that's only aluminum on a turbo appl. and the roof is seeing the most heat... plus your pedestals are built into that all.. well that's not very smart engineering.
I'm leaning towards something like Charlie did.. moving the clamping down to a much cooler/reliable area but retaining height with material B. PS. Found this VERY informative cutaway picture from member 7T2 showing the center of the E-heads. KRIS.
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
I made the .250" thick x 1.00" O/D washers on the lathe and then hardened them (heat to cherry red and drop into cool water). You can buy thick hardened washers from engineering outlets -they are used for tool or work piece clamping.
The Following User Says Thank You to taff2 For This Useful Post: | ||
How much torque are folks applying to studded E-heads with ARP lube on all contacts? I remember reading on here as low as 85-90 ft-lbs.. !!
@ adynes is that on a turbo application ? Install sheet as a reference:
Yeah. Don't have any pictures on my current phone. Not a ton of run time since first run in 2017; car is a work in progress.
Thread Tools | |
Display Modes | |
