Old 07-30-2021, 11:00 AM
er455 er455 is offline
Default REAR GEAR CHANGE
Hey guys looking for advice. Wanting to change my rear gear from a 3:08 to either a 3:42 or 3:73 , I am running a 29” tall tire now and with my turbo set up i want to kept my rpms at the end of the 1/4 mile around 6,000 also. I have a 4l80e so not worried about freeway rpm …
Old 07-30-2021, 11:35 AM
Stan Weiss's Avatar
What et and MPH will it run? What are you seeing for convertor slippage?
3.42:1, 6000 RPM, 29" tire, no / zero convertor slippage - 3rd gear 151.4 MPH - 4th gear 201.8 MPH
3.73:1, 6000 RPM, 29" tire, no / zero convertor slippage - 3rd gear 138.8 MPH - 4th gear 185 MPH
Stan
Pontiac Pump Gas List
Old 07-30-2021, 03:13 PM
Default Gears
Stan
Thanks Stan. I guess the 3:42 would be the one to go with as I think the car will run 9:30 to 9:60 on 15 lbs of boost and E85 just a lot of work to go from 3:08 to 3:42 such a little change hope it pulls better down low ….
Old 08-01-2021, 04:10 PM
tallrandyb's Avatar
tallrandyb tallrandyb is offline
What rear do you have? I have an 8.2 BOP 3.55 gearset with open carrier.
Old 08-01-2021, 04:13 PM
8.5 with a 3.08 gear now
Old 08-01-2021, 05:13 PM
tallrandyb's Avatar
got it. I just listed the 3.55's for an 8.2. Good luck with your search!
