Old 08-23-2021, 05:03 PM
cnc's Avatar
cnc cnc is offline
Default Hood hinge Issue or something else??????
So ive had the car painted and the hood adjustemt is not right....
I've talked with Craig (Norwood) about the hood and the latch issue I also have ...I've ordered a latch ....
My biggest concern is the hinges ...I now have the rear hinge bolts at the top of the slot so the hinge is down in the rear .....the problem I'm having is the hinge seems to not want to allow the hood to close down to the core support ...it's like the hood stops and I'm have to force the hood down I'm afraid of buckling it if it's not already maybe....
The frt of the hinge adjustment slot the bolt is also at the top of the slot...so frt and rear bolt position is in the top of the slot...
It's like I'm fighting against the hinge as its like it won't fold together enough to let the hood close????
Hinges were rebuilt By Willie Wilson in Virginia
Anybody else had this issue ??????...Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 08-23-2021, 07:58 PM
On my Lemans they were very finicky. Try moving them a bit in the other direction. They are deceiving how they work. If your at the top of your slot, move the hinge upward and that will bring the front down.
Old 08-24-2021, 07:24 PM
cnc's Avatar
cnc cnc is offline
Here is a video of what the hood is doing …..the clicking snap noise is the hood latch
https://www.youtube.com/watch?v=Yvp97tcm2zk
Old 08-25-2021, 12:52 PM
Are the bumper stops in the rear pushing it up? Do they need lowering?
Old 08-25-2021, 01:10 PM
78w72 78w72 is offline
just a guess but looking at the video the hood in the rear seems like its actually sitting too low, which is from or related to how the hinge is adjusted, you said the bolts are at the top of the slots meaning the hinge is pushed all the way down & when you are trying to latch it, its lifting the rear of the hood up as you noticed.
the common thing on these hoods is that they sit up too high in the rear so people lower the rear of the hinge to improve or fix it... yours might have the opposite thing going on where the rear of the hood is too low how its currently adjusted, so as mentioned above, try raising the rear of the hinges some, maybe halfway & see what that does. can always go back to how it is & cant hurt to play with the adjustment of the hinge some. maybe youve already done that but thats what it looks like in the video.
& i noticed the car is a firebird but has a T/A shaker hole, couldnt tell if it was a formula hood with a hole cut... is this a clone T/A or are you gong for the "chips ponch" firebird hood look? or the SD forumla with a shaker look?
Old 08-25-2021, 06:12 PM
cnc's Avatar
cnc cnc is offline
I’m going to try some of that stuff for adjustment this weekend maybe
Here’s the look I’m going for …shaker hood rear spoiler stripe 70-72 car
Old 08-25-2021, 06:13 PM
cnc's Avatar
cnc cnc is offline
No they are not even close ….
Old 08-25-2021, 07:33 PM
that looks cool with the T/A stripe. ive seen the red t/as with the stripe but not any orange ones. i have a 72 firebird with a formula hood, i wanted to try using the stripe but it doesnt fit right between the scoops.
Old 08-26-2021, 06:34 AM
cnc's Avatar
cnc cnc is offline
Thanks paints not quite that colour orange of the attached pic but that’s the look …hope it looks as good as I hope ….lol
Old 09-20-2021, 07:17 PM
cnc's Avatar
cnc cnc is offline
So ....I just received the new 10 catch Latch from Norwood ...what a beautiful piece and works like butter.....VERY Happy with it ....
I'll be adjusting the hinges now that I have this addressed....
So if u ever need a latch Norwood is the man.....
Old 09-20-2021, 10:10 PM
694.1 694.1 is offline
Does he do hinges?
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 09-20-2021, 10:18 PM
cnc's Avatar
cnc cnc is offline
Originally Posted by 694.1 View Post
Does he do hinges?
No he does not I think I asked him a while back ..do a search I'm very happy with mine ....I believe there is a gentleman in California as well....and I'm sure others too...
Old 09-21-2021, 09:24 AM
that looks nice... what is a 10 catch latch?
Old 09-21-2021, 05:52 PM
cnc's Avatar
cnc cnc is offline
Well in 1970 ( one year only I believe Craig said ) they used a 10 catch and after that they went 3 catch latch..
If u look at the latch from this pic the lower left pivot is the piece that rides against the catch which has 10 notches in it, it sits behind the safety catch.
This making the hood closing have more adjustability with the extra notches..
This piece is top notch….Norwood does awesome work…..and great to deal with…..
Old 09-21-2021, 06:05 PM
cnc's Avatar
cnc cnc is offline
Here is a comparison
Old 09-21-2021, 07:01 PM
cool, i was not aware of the 1970 10 catch thing.
Old 09-21-2021, 08:03 PM
cnc's Avatar
cnc cnc is offline
Me either till I started looking into trying to fix my issue ….others have had the same problem as myself…..
