Old 10-15-2021, 06:48 AM
Elarson's Avatar
Elarson Elarson is offline
Default Formula Wheel Horn Button Removal
I'm getting ready to swap a steering wheel and need to remove the horn button. I've done that before but it's been 25+ years ago and I don't remember exactly what was involved. So remind me....does it just pry straight off or does something else need to be done to disengage the grippers?
Thanks,
Eric
Old 10-15-2021, 07:58 AM
M91196's Avatar
M91196 M91196 is offline
I pull it while I put a little pressure on a finger with a pick to ease the pressure.
Old 10-15-2021, 09:50 AM
78w72 78w72 is online now
yes just pry it up at any location & it should pop off. usually just your fingers will work if you can get under an edge, if not a small putty knife or pry bar slid behind it.
Old 10-15-2021, 01:15 PM
Formulabruce's Avatar
If you need your collar redone to perfect factory look with much better durability, I will be doing these again this winter.
