Old 04-19-2003, 09:32 AM
noob_goat noob_goat is offline
How difficult is rewiring a '69 GTO using a Painless harness (http://www.painlessperformance.com/harness4.htm)?
I am a complete amateur. It seems (seems) like it shouldn't be too horrible a task given the instructions that come with the kit and the existing wiring to act as a guide.
Is it something a monkey could do (a determined monkey) or am I setting myself up for a lot of pleasant evening driving with the inerior lit by sparks shooting out of the dash?
Old 04-19-2003, 10:33 AM
Tom McQueen Tom McQueen is offline
I am currently rewiring my 70 GTO. While the kit is called 'Painless', and its very well made and complete, the actual task of putting it in is anything but. Welcome to my nightmare.
Check out my 70 GTO build;
http://www.yellowbullet.com/forum/sh....php?t=1148602
Old 04-19-2003, 03:18 PM
walsh1 walsh1 is offline
i would look seriously at replacing the harness with the ones you can get at PY. Its a simple plug and go and I suspect youd save a lot of agrevation by the time your done.Time is money.
I replaced the front end and engine harness on mine and it was very easy.
Old 04-30-2003, 09:25 PM
acowboy acowboy is offline
oh man tom...i never knew what a flashback was until i saw your pic!!!!! hahahahahaa
Old 04-30-2003, 09:29 PM
Brady, if it wasnt for the fridge full of beer I would have slashed my wrists a week ago.
Old 05-01-2003, 05:38 AM
David Jones's Avatar
M&H
http://kurtspontiac.homestead.com/DavidJones69GTO.html
Old 05-11-2003, 05:02 PM
ErikW's Avatar
ErikW ErikW is offline
Painless kits are great if you are staring with nothing or wiring a street rod / race car. I agree with ohio69 about the direct replacement sets if your just trying to repair under the dash or engine compartment. However, if your car is like most of that era it's pretty much been butchered from one end to the other and the painless kit would be more cost effective. They are very complete and of excellent quality. Good Luck!
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
Old 05-11-2003, 08:46 PM
I had no choice but to start over. The original wiring was what, 33 years old? And Im adding electric windows, remote keyless entry, AC where there was no AC, electric mirrors, electric fuel pump, electric fans, complete Autometer dash, etc. This is one of those experiences you have to do once just so you can say 'never again'.
Old 05-12-2003, 07:55 PM
i did the painless route with my 70 el camino, and like tom above,,was wore out before i got it done.....and like the post above, i did my 70 goat with M&H,and was easy as pie...but, it was stock redo...with all the addos you have, dont know which way i would go..........lotsa luck!!!
Old 05-12-2003, 09:43 PM
JC455 JC455 is offline
Tom,
The harness that you're installing- does it include bulk head connections? If not, how are you wiring it-- are you installing a bulkhead, or are you just going straight into the engine bay?
Thanks!!
John
John
IG: @crawdaddycustoms
YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos
Old 05-12-2003, 10:01 PM
This is the 18 circuit GM musclecar kit. It goes right into the same opening the factory fuse box came out of. Has a very stock looking loom coming out the other side (into the engine bay) and seals very nicely. Like my original post said, its a great kit. Very well thought out. Im just not what you would call an enthusiastic electrician.
Old 05-14-2003, 05:39 AM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
I thought about using painless until I found M/H. There wiring harness fit great. Plug in and go, and I wired in a electric pump, HEI, MSD, Auto meter guages, line lock, and now Nitrous with another electric pump. Whats good about the stock harness is that options like rr defrost, console and such just plug in just like at the assembly plant.
M/H has a tech line that came in handy also.
Just my .02. Good Luck
All good things are worth waiting for. "Yeah right", I want them now!
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph
Old 06-22-2003, 09:42 PM
TIAUTOMAN TIAUTOMAN is offline
I had very good luck with the painless kit.
No problems what so ever.
I even used the universal dash harness for my autometer dash. No problems what so ever.
If you can read a schematic, you can rewire the car.
Old 06-23-2003, 08:12 PM
mick mick is offline
Can someone tell me what M/H is.???.. I also need to rewire my 71 GTO thanks
Old 06-24-2003, 01:44 AM
kate`s67gto's Avatar
kate`s67gto kate`s67gto is offline
M/H is a wiring fabricator manufacturer. They make wire harnesses for muscle cars and the likes.
I got mine from them with HEI and setup for internal voltage regulator. Just go to your search engine and type m/h wiring. that should get you to there web sight .
Scott
If you always do what you always did
You always get what you always got
