Old 05-03-2022, 03:54 PM
grandam1979 grandam1979 is offline
Default Speedometer reducer who has had one?
Got this on a trans I picked up over the weekend I was told it was removed from a mid seventies t/a it’s a turbo 350. I haven’t seen one before it’s marked 1.300 why would they have needed this ? For a low gear option car without transmission change?
ID:	590072   Click image for larger version
ID:	590074   Click image for larger version
ID:	590075   Click image for larger version
Old 05-03-2022, 03:59 PM
JLMounce JLMounce is offline
These are utilized to correct speedometers when the drive/driven gear combination is not available for the rear end gear/tire combination.
I have one on my 69 bird for that reason.
-Jason
1969 Pontiac Firebird
Old 05-03-2022, 05:43 PM
1969GiPper 1969GiPper is offline
In 1989 I broke the 3:23 ring & pinion in my GP and replaced it with a 3:90. To get the speedo to read accurately I had to use a reducer. Ordered mine from the GMC Truck Center in Pontiac, Mi. Worked great. Removed it when I changed rear to a 3:36 gear a number of years ago. If I remember correctly there was a chart in the parts book to figure out what ratio and part number you needed.
Old 05-03-2022, 05:58 PM
67drake's Avatar
67drake 67drake is offline
I actually have on on my GTO. It came with 3.23’s, and when I went to 3.90’s I just used the reducer. It’s been on there so long, I can’t remember why I went that route. Maybe I couldn’t find the correct speedo gear. Sorry, getting old, and CRS.
13.95 @ 102.1 on street tires @ 4055lbs.
Old 05-03-2022, 06:22 PM
Ogre's Avatar
Ogre Ogre is offline
This worked for me many years ago. Performance and Transmission Center (PATC).
Good company to work with.
Ogre
ID:	590101   Click image for larger version
ID:	590102   Click image for larger version
“Man will ultimately be governed by God or by tyrants.”
-- Benjamin Franklin
- (1706-1790) US Founding Father
The Following 2 Users Say Thank You to Ogre For This Useful Post:
Old 05-03-2022, 06:23 PM
PDC PDC is offline
Yes! I just got one of these about a month ago from this place:
https://transmissioncenter.net/shop/...1-888-2012066/
I had maxed out the number of teeth on the Driven Gear for my T56 and with a 26” tire and 3.70 rear gear, my speedo read exactly 10% fast. The 10% reduction is a ‘standard’ reduction that PATC had on the shelf and they shipped it right out. I installed it in under 10 minutes and the speedo reads dead on with my Phone app GPS speedo.
Old 05-03-2022, 07:00 PM
carbking's Avatar
carbking carbking is offline
Have a similar device on my GTO. Because of the special 4-speed I used, speedometer cable from transmission not an option. Went with a electronic speedometer control that counted pulses from a device attached to the driveshaft, and then had a speedometer cable to the dash speedometer. Once programmed, it works as well as any gauge. Will work with any rear end ratio and any speedometer that accepts a cable.
Jon.
The Following User Says Thank You to carbking For This Useful Post:
Old 05-03-2022, 07:08 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My 78 TA with 2.56 rear gears had one.
Skip Fix
Old 05-03-2022, 07:43 PM
Verdoro 68's Avatar
I had one on my car for a while. I was running a late '70s Cadillac TH400 with a drive gear that had 18 teeth. They don't make a driven gear that would get my speedo to read correctly with 3.55s so I had to run a 17.6% drive reducer.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 05-04-2022, 08:22 AM
Half-Inch Stud's Avatar
Have two GM Speedo cable 1:1 right angle units. No use
Have the Electric Pickup Speedo ASSY shown in Post 5. Neato
Speedo does work in my 68 4L80 combo anymore due to Drive Gear slipping on Tail shaft: must make amends.
Jon, got a link or name of youe ElecSpeedo Drive?
Old 05-04-2022, 09:24 AM
Singleton Singleton is offline
My original drivetrain 78 T/A with 2.56 has one also
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
