EFI Tech All things EFI and making classics modern!
Old 04-03-2022, 04:23 PM
gman005's Avatar
gman005 gman005 is offline
Default Holley Sniper time
Well I started my efi swap.
ID:	587863   Click image for larger version
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 04-03-2022, 04:34 PM
Scott65's Avatar
Scott65 Scott65 is offline
Cool, keep us updated as you go.
Old 04-04-2022, 09:13 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Cool. Which system are you using?
Old 04-09-2022, 07:56 AM
gman005's Avatar
Still waiting on the new gas tank bolts to show up.
71 Lemans Sport.
72 Lemans Sport.
Old 04-09-2022, 09:20 AM
Scott65's Avatar
The appropriate length bolts with heavy duty flat washers will make a good place holder til the t bolts show up, if it's holding you up from running lines, and wiring. Just fyi
Old 04-10-2022, 09:16 AM
gman005's Avatar
The bolts came yesterday afternoon. I got the tank and the vent installed.
71 Lemans Sport.
72 Lemans Sport.
The Following User Says Thank You to gman005 For This Useful Post:
Old 04-10-2022, 11:09 AM
Slow and steady is the game. Do it right, do it once.
What tank and pump did you go with?
-Jason
1969 Pontiac Firebird
Old 04-11-2022, 05:57 AM
gman005's Avatar
It is a Tanks tank and pump.
71 Lemans Sport.
72 Lemans Sport.
Old 04-11-2022, 10:24 AM
You'll be happy with that setup. I run a Tanks Inc. tank with their GPA-4 module. I've had it in the car since 2015 and about 25000 miles. It's a solid, reliable setup.
-Jason
Old 04-11-2022, 06:11 PM
gman005's Avatar
I am using 550-516 with the GPA-5 pump. I bought the setup from a member here but i'm not going to use the dist,coil, and the hyper spark. I want to use my ignition setup.
71 Lemans Sport.
72 Lemans Sport.
Old 04-11-2022, 11:43 PM
Run the timing control with the system. I ran my traditional ignition setup with my FiTech up until last year for simplicity sake. The difference is night and day.
Yes the initial setup is a little bit more complex, but once the setup is complete the tunability in the system grows… a lot!
For me, throttle response increased further, fuel mileage increased, engine runs cooler and I gained a full 1.5” of vacuum.
I don’t run a massive cam at a 232/238 112 but the timing control really tamed the combination compared to the HEI. So much so that I’m really after a much more aggressive cam at this point.
Good for thought.
-Jason
Old 04-12-2022, 07:53 AM
Scott65's Avatar
^truth. I run a 242/251@.050 hyd roller that will easily idle at 850 rpms. I haven't attempted to go lower cause I don't need to. Being able to manipulate the timing in a non linear manner makes a lot of difference.
Old 04-22-2022, 04:24 PM
gman005's Avatar
Finally got the plumbing done. Now on to wiring.
71 Lemans Sport.
72 Lemans Sport.
Old 04-26-2022, 02:47 PM
What kind of combination is it going on?
https://youtu.be/XqEydRRRwqE
Old 04-27-2022, 06:04 AM
gman005's Avatar
It is a stroked 400/462 with eheads.
71 Lemans Sport.
72 Lemans Sport.
Old 04-27-2022, 11:01 AM
Neat!! Can't wait to hear how that turns out for you and how you like it...(or not)
Old 04-27-2022, 01:27 PM
napster's Avatar
napster napster is offline
To OP,
I had the Sniper system installed on my '70 GTO. It had the Fi-Tech on it. What a change. I think you will love it, I know I do. My '70 has a 400/462 in it with edelbrock heads like your car.
Good luck with it.
Old 04-27-2022, 02:12 PM
What do you like better about the Sniper over the Fi Tech? Fi Tech has a pretty big following too and seems to be reliable. You can PM if you wish. I'm just curious.
Old 04-28-2022, 01:14 PM
napster's Avatar
Already answered this in another thread. Starts with post #9 as a question from another member.
https://forums.maxperformanceinc.com...d.php?t=855151
Old 04-28-2022, 01:22 PM
Okay, I wasn't part of that thread and I've been away a couple months.
I had never heard of the Fi Tech not retaining it's learn table when the battery is disconnected, that's interesting.
