Old 02-23-2022, 08:23 AM
NAPA68 NAPA68 is offline
Default 71 455HO TCS
it was recently pointed out to me (at the 2021 MCACN) that a 71 455HO should have a TCS system like all of the non HO applications. After looking through the factory shop manual, my take away is the HO cars were not equipped.
Naturally, I was dinged points as I was not able provide a valid counter point to the conversation.
If it is supposed to have it, anyone have a nice survivor type solenoid around?
Thanks,
Tim
Old 02-23-2022, 08:52 AM
455 HO uses 'TVS' system. There would be a fitting in same spot as TCS.
Just found this in parts book:
ID:	584730   Click image for larger version
ID:	584731   Click image for larger version
ID:	584732   Click image for larger version
Old 02-23-2022, 09:38 AM
FrankieT/A's Avatar
How does the system know when the vehicle is in high gear?
Old 02-23-2022, 09:56 AM
AG's Avatar
AG AG is offline
A switch on the trans when shifting into 4th gear with a manual trans.
Old 02-23-2022, 10:08 AM
Thanks for the replies so far guys. So if I am reading the provided information correctly, the 455HO just uses a ported vacuum switch regulated strictly by engine temp (which I have).
I was informed it should have the vacuum switch which was electrically controlled by the trans when it's in 3rd or 4th gear.
Sorry if I am not explaining myself properly or complicating things. I am very familiar with TCS systems from my Corvette background.
Just wanting to make sure I have thing correct on my car, but do not want to alter anything due to a misinformed judge.
Old 02-23-2022, 10:25 AM
I don't think the 455 HO had a switch on tranny to control the TVS?
(or had a TCS vacuum switch for distributor)
It didn't need it? Just temp.
It was just vacuum operated. (and heat from intake crossover)
Another page on checking the TVS (455 HO)
1971 TVS
(full page link so not crunched down by PY)
Old 02-25-2022, 05:04 PM
giles's Avatar
giles giles is offline
No TCS on a ‘71 HO. They have a thermal vac switch on the right front of the intake. It has a ported vac input and a manifold vac input, and distributor advance output ( so 3 ports) Then the thermal switch opens one vacuum source cold and the other when hot, but no dist vac advance during normal operating temp. Not the best for driveability but sure lowers NOx emissions.
It is documented in the ‘71 service manual and assembly manual.
Old 02-25-2022, 06:19 PM
Kenth's Avatar
Kenth Kenth is offline
FYI, there IS distributor vacuum advance during normal operating temperature while driving above idle speeds with 1971 455 HO TVS system so driveability will not suffer at all.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-25-2022, 06:44 PM
giles's Avatar
FWIW
Good call! I was going from memory. Pulled out my service manual. The TVS allows manifold vacuum above 230F, and only ported vacuum below 230F. So no vac advance at idle except when very hot.
Old 02-25-2022, 07:25 PM
hiyabradHO hiyabradHO is offline
Removed and posted new thread
Old 02-25-2022, 07:42 PM
eaglesan13 eaglesan13 is online now
Tim,
As you have recently observed, the 1971 455HO did not use the TCS system. However, when I owned your car, I noted that there was a TCS switch installed in the transmission, but there was no wire plugged onto the switch.
A few days ago I pulled the engine and trans out of my 1971 Formula 455HO and found the same thing. A TCS switch is installed in the transmission, but there is no wire connected to it, and no TCS solenoid on the engine.
Thanks,
Tim
The Following User Says Thank You to eaglesan13 For This Useful Post:
Old 02-25-2022, 08:59 PM
I'd imagine the Muncies all came with the hole for the switch and they put a TCS switch in there? (instead of pipe plug)
Also probably they don't know what vehicle/engine will get the tranny, so all have the switch in it.
Old 02-28-2022, 10:01 AM
Thanks everyone for the help!
Tim
