Old 01-04-2020, 07:57 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
Ok, so ours ended up not getting delivered today, but it should on Monday
1978 Trans Am
Pump Gas 461 Stroker
  #102
Old 01-05-2020, 10:29 AM
I do have mine in hand and it looks correct compared to an old used one I’m not at home right now to take pictures I’ll try to make that happen soon
The Following User Says Thank You to Tellyshavilli For This Useful Post:
  #103
Old 01-05-2020, 10:42 AM
Thanks Matt
1978 Trans Am
  #104
Old 01-05-2020, 08:13 PM
hiyabradHO hiyabradHO is offline
Ours will now be delivered on Tuesday.
  #105
Old 01-05-2020, 09:21 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Ugh! The suspense! 😳
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
  #106
Old 01-06-2020, 05:34 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Pictures...
ID:	528308   Click image for larger version
ID:	528309   Click image for larger version
ID:	528310   Click image for larger version
ID:	528311   Click image for larger version
So long, farewell.
  #107
Old 01-06-2020, 05:40 PM
Transamric's Avatar
Pictures...
Thanks for the pics. Looks like the outlet is SLIGHTLY rotated from the originals. But I'm assuming close enough to be workable.
  #108
Old 01-06-2020, 05:47 PM
We got our SP1304MP from RockAuto earlier too! Here are some pictures of ours, although we don't have a stock one to compare it too, it looks correct....
ID:	528313   Click image for larger version
ID:	528314   Click image for larger version
ID:	528315   Click image for larger version
ID:	528316   Click image for larger version
1978 Trans Am
  #109
Old 01-06-2020, 06:04 PM
We are installing ours right now with the new engine on the stand, and I can report that the new Ames FN327 Carb to Pump Fuel Line and the new SP1304MP Spectra Fuel Pump works great together with factory 1970 7040270 Qjet with short filter housing.. We did have to tweak the end of the line down at the pump, just very, very slightly to get it to line up perfect, but it was very close and now works perfect after that minor adjustment.
1978 Trans Am
The Following 3 Users Say Thank You to TransAm 474 For This Useful Post:
  #110
Old 01-06-2020, 07:51 PM
Here are some more pictures after installation. This is a YZ RA III 400 out of a 1970 Trans Am we are currently building for a friend of ours.... We went with some internal upgrades, while retaining the numbers matching, "stock appearance" look on the outside. Here are some specs of the combination
1970 YZ 400 .030" over
Zero Decked
Stock N crank
Eagle 4340 H-Beams
Icon forged dish piston 14cc
Total Seal Classic Rings
Stock #12 heads, Ferrea Stainless valves, 7/16" Studs and Polylocks, 70cc chamber
Felpro 1016 .039" head gasket
Quench .039"
9.8-1 compression
Summit 2802 camshaft
224/234@.050 .466/.488 lift 114° L.S.
Stock 1.5 rockers
Stock '70 Cast Iron intake
Stock 7040270 RA III Qjet Recalibrated with Cliff Ruggles parts
Stock 1112009 RA III points distributor recurved by Cliff Ruggles
RA III Exhaust manifolds, dual 2.5" exhaust
TH400
Hughes GM25-BPO 23-2500 stall Converter
3.55 rear gears
Here are some pictures of the pump and Line installation
ID:	528331   Click image for larger version
ID:	528332   Click image for larger version
ID:	528333   Click image for larger version
1978 Trans Am
  #111
Old 01-06-2020, 10:10 PM
Norwood's Avatar
Norwood Norwood is offline
Just look how excited we are getting over a fuel pump.
The Following User Says Thank You to Norwood For This Useful Post:
  #112
Old 01-07-2020, 02:15 AM
Okay. Mine can in today from AutoZone. It’s the same pump SP1304MP and $39.99!
AutoZone uses their own part number: B1304MP. You can see the original part number under the AutoZone label.
ID:	528373   Click image for larger version
  #113
Old 01-07-2020, 06:48 AM
WOW, so AutoZone is by far the cheapest place to buy it then, with RockAuto being second cheapest that I've found... Great to know! Thanks for sharing
1978 Trans Am
  #114
Old 01-07-2020, 11:15 AM
unruhjonny's Avatar
wow - that's a big price difference too!!
I just looked it up, on Rockauto one is $72.36cnd ($55.60usd);
While that AZ unit is $52.04cnd ($39.99usd);
That's a twenty dollar difference!!!
I know exchange is miserable right now (and not forcasted to get better any time soon), but sheesh...
Btw, I looked, and the cheapest I found on eBay was chump-change away from $100cnd before shipping... eek!
Well, I hope these don't sell out too quickly because I am holding off for the moment.
1970 Formula 400
  #115
Old 03-17-2022, 07:05 PM
unruhjonny's Avatar
I've never forgotten about this discussion, and would on occasion look these up to see if there was a price drop, but it looks like there never was for Canadians - then the listing disappeared the last couple times I looked.
It's not currently up on Rockauto either.
We don't have autozone up here, so if they can still get these, that's great - but with the borders more or less closed for the last two years, that's never been an option for me.
But I also have been keeping an eye on old stock Pontiac Fuel pumps;
I came across a number very recently that I couldn't cross reference when I stumbled on this listing - and snapped it up.
It was a great price, and really reasonable shipping (which is extremely rare these days for Canadians);
I just received it, and sure enough the box says 40959, but the part is stamped 40838 - this must be a really old part!!
Name:	old stock fuel pump ebay b.jpg
1970 Formula 400
  #116
Old 03-18-2022, 03:51 AM
Formulabruce's Avatar
I have bought many old stock pumps, and they all had issues with ethanol in fuel. Where? at the crimp point. I have had a couple showers under my lift.
Enjoy the wall hangar unless you are buying or making Non alcoholic fuel...
  #117
Old 03-18-2022, 09:16 AM
unruhjonny's Avatar
around here at least, it's easy to stay away from ethanol free premium gas.
1970 Formula 400
  #118
Old 03-18-2022, 02:27 PM
Has anyone installed this on their car? If so, how is it working?
  #119
Old 03-18-2022, 04:20 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
I remember Big A Auto Parts. They went out of business in the late 90's. At best it's about 25 years old.
  #120
Old 03-18-2022, 04:29 PM
FASTASSBIRD FASTASSBIRD is offline
Runs my 71 trans am just fine. Got video of it trying to knock a can of brake clean off the cowl lol. No issues so far
