Old 06-15-2021, 05:51 PM
sdbob sdbob is offline
Default Anyone know a reliable ignition coil for breaker points?
I'm looking for a stock looking coil. I'll be using it in one of my SDs. Seems all is china made.
Old 06-15-2021, 05:58 PM
padgett's Avatar
padgett padgett is offline
With or without a resistor ? Delco U505 maybe ?
Web Site
Old 06-15-2021, 06:21 PM
If you do not have a show car just about anyone will be 100% reliable if you mount it on the firewall where there’s little vibration and little heat conduction which is what kills them over time.
If not then Franks Pontiac parts has original used Delco coils so screw thinking about aftermarket ones, especially China made ones!
If your stuck with mounting it on the engine then find some thin non cork gasket material and make a heat insulator for the coil bracket.
Old 06-15-2021, 08:14 PM
i82much's Avatar
i82much i82much is offline
what about an msd high vibration coil?
Old 06-15-2021, 08:37 PM
Schurkey Schurkey is offline
I get 'em at the Treasure Yard. Dirt cheap--if you can find 'em.
Best I can tell, the contact with a metal bracket would REMOVE heat from the coil. It'd have to be damned hot under the hood for the bracket to put heat into the coil.
Old 06-15-2021, 08:43 PM
MSD 8222 has only 0.8 ohms primary resistance. You'd have to add more ballast resistor or you'll cook the points.
MSD 8252 is even worse--0.2 ohms.
Manufacturers were mounting oil-filled "canister" coils on the engine since the Dark Ages. I don't know why vibration is suddenly a problem--except that the Fookin' Communists just make crappy products.
Old 06-15-2021, 09:56 PM
On the points cars I use the Accel 8140 and just paint it black. Looks stock.
I've had one on the Firebird for 25 years, still works fine.
I've also used the MSD 8203 on other cars with points that also works fine. Again, paint it black.
https://youtu.be/XqEydRRRwqE
Old 06-15-2021, 10:30 PM
abefromen's Avatar
abefromen abefromen is offline
O'Reilly's Auto Parts, Master Pro, 2-5195. Chinese coil, but it is of excellent quality.
Or pick up a NOS GM coil all over ebay
Old 06-16-2021, 01:13 AM
Ram Air IV Jack's Avatar
Ram Air IV Jack Ram Air IV Jack is offline
Very true!!! I still have my original 410 coil on my 69 GTO. Works great and looks as good on the scope too. Still mounted in its stock position...
Old 06-16-2021, 06:39 AM
Thanks for all the responses. I have about 5 old GM coils but with my old old analog meter show infinite resistance. Today I'm getting new Fluke meter and trying echlin coil. I just try to avoid chinese stuff but 2 parts guys said almost impossible.
Old 06-16-2021, 08:02 AM
Yep just about impossible. I just don't worry about it anymore.
Old 06-16-2021, 04:13 PM
Got napa. Points, condenser, coil made in mexico.
