Old 06-14-2021, 11:24 PM
Tom Vaught's Avatar
Boost Engineer
I'd run a hydraulic flat tappet, with Rhoads and the lube face option, or go with a solid flat tappet, again with the lube face option.
I've been running one engine with a tight lash solid flat tappet, using Comps EDM lube option for the lifters and so far have 50,000 miles on that engine. The lash hasn't budged since break in. It's been a perfect setup.
X2!!! I was a solid lifter guy and flat tappet cams for many years even though I had at least two "streetable" roller cams on the shelf. I chose to run a flat tappet HO Racing camshaft from Camshaft machine Company and a set of hydraulic Rhoads lifters in the 64 GTO my son will be driving. 455 engine.
Not regretting that decision for a second.
Tom V.
Old 06-15-2021, 12:47 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Originally Posted by TedRamAirII View Post
I have this guy that wants a Solid Roller for his street car. 69 400, .030, 48 heads, th400, 3.23 gears, Qjet, Performer Intake, stock rockers. . I suppose he's afraid of a Flat Hydraulic Lifter issue. So what cam? He sad he has Crower Lifters 66260, but doesn't know what cam to get. Don't think he wants more performance , just reliability, but if HP goes up, I don't think he will complain about it. I was thinking a Butler RAIV Retro with the solid roller? and ideas? What about Valve Springs? I ASSUME they need to be changed? Don't want to be pulling heads, just a cam swap and new timing chain gears. I don't know what he has for a cam , I dont even think he knows, sounds a little more than stock. He bought it that way.
He would love my old street solid roller I originally used in my 400 68 GTO (auto w 2.93 gear) Ultradyne (by Bullett) the smallest one. adv 279/290 242/252 @ 050 LSA 112 ICA 106or 107 .556 .556 about .540" net after lash with 1.5 // its was super streetable daily driver never came out of adjustment put a couple thousand miles on it with crane solid roller and zero mods to oiling. Currently still in my 11 sec 455 Catlalina 455 combo but coming out this year when my fresh 467 stroker block goes in with a bigger one
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
Old 06-15-2021, 12:55 PM
Thank you Steve. He doesn't want to get into pulling heads off. I think he has been on a "Hybrid state of mind", with all the Hydraulic issues. According to the chart, they don't like the 041 in a RAIV 400?
solid roller and not pulling heads and isn't good. I planned mine on my #16's 68 heads and went to longer RA IV valves to give me tons of room for high lift and tall proper spring set up. went with a a Herbert spring #175 on seat which is listed for solid roller and seems mild but has always worked flawless but I also never revved it past 6200 but I also did titanium 10 degree retainers.. the tall springs got also matching longer thick wall butler pushrods all of it 14 years or so later still working flawless
Old 06-15-2021, 04:27 PM
Steve C. Steve C. is offline
242/252 @ 050
112 LSA
.556 / .556
That cam Larry shared above. It's listed in the Pontiac section of my old UltraDyne catalog. Their description states:
"very streetable, 2500SS converter. Broad torque curve."
Old information here:
Old 06-16-2021, 08:47 AM
Formula8's Avatar
Formula8 Formula8 is offline
Originally Posted by David Jones View Post
I’ve run .005 on my Comp/Crower hybrid now for nearly 10 years. Last couple of times I ran the lash proved to be a “feel good” thing, more than anything. Much quieter than the hyd roller lifters I took out.
I don't have a ton of miles on my hybrid but have checked/changed the lash 3 times more out of curiosity than anything else and this has been exactly my experience as well.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 06-17-2021, 08:01 AM
Originally Posted by Steve C. View Post
242/252 @ 050
112 LSA
.556 / .556
Yep its true I had a Hughes HD BOP GM25 12" 2500 rated converter worked good with 14" tires and 2.93's with that cam in my old GTO. Also on a road trip to race the Pontiac event in Tulsa back then I managed almost 15 MPG with that roller and my trusty 800 Quadrajet
I still got the converter behind our hot rod farm truck 74 C10 454 w 3.07 gear
