#61
It's all good. I have a bit of a temper and own that part. Peace!
#62
BUT when you get on a forum and give your opinion and someone else then follows that opinion, now you have potential safety issues. Your vehicle (the 64 vehicle) as you know does not have seat back locks, or headrests. A very unsafe situation which was corrected years later when safety standards were put in place for manufacturers and component designers. Pontiac Engineering was not perfect by any means when they designed the A-Body Vehicle in 1964. Neither was Chevrolet. The frame and crossmember was far from being perfect. But it was designed by a designer for a given power level. And then the racers installed bigger and better traction tires and wheels and the owners broke the frames. A common issue was tearing out the right upper rear frame crossmember, (so Pontiac designed the pieces to reinforce that area of the frame). It was a warranty fix and a potential frame upgrade modification to the A-Body cars. Point being, Pontiac Designers designed parts to a given specification. If you did not beat on the vehicle the rear cross-member issue would never appear. So the drivers/owners caused the issues and then blame the Designers for designing sub-standard parts. Pontiac used the "Biscuit" and Clamp" design on the A-Body vehicles for the production life of those A-Bodies. Good or bad, it is what they did. Right or wrong, you have your opinion on what is a better design vs the Pontiac design. Pontiac is dead. The Pontiac Police are not going to come and see you for modifying your cross-member in your 1964 vehicle. Do whatever you want with your vehicle. Just don't throw rocks at people who actually did the job for a living and designed a given part based on direction from their upper management. That comment being said, I personally have a problem with the Cooling and FEAD Design Engineer who changed his design for those systems every year on the 1964 thru 1972 A-Body Model Years. Examples are: Pulleys are different year by year, water pumps are different, timing covers/water pump flow is different, Power steering stuff is different, and the list goes on and on. We can have a thread on that guy and his constant changing of component designs vs the common Chevy design pieces. "If you have never done the Job for a Living, you have an opinion. You may have experience with different parts but you are not an Engineer or Designer." Jim Clarke, a Ford Chief Engineer, said One Piece of DATA is work 10,000 Opinions. You have your opinion, I have mine, modify your cross-member to your hearts desire. Tom V.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 06-29-2021 at 09:23 AM. |
#63
The Following 3 Users Say Thank You to JSchmitz For This Useful Post: | ||
#64
Looks like Chief of the 60’s might have some company…….
#65
Please.
Closed Thread |
