Old 12-19-2023, 08:49 PM
Default After market tilt column
Has anyone here used an after market (Flaming River, Ididit etc) tilt steering column in a 1962-1964 full sized Pontiac? If so what did you use and what had to be changed? I can't find a good original and people want almost as much for a worn out one as the new ones cost. They list one for an Impala. Are they very different? I know that the wiring has to be modified but I would like 4 way flashers anyway.
Old 12-19-2023, 11:24 PM
694.1 694.1 is offline
A '63 Chevy tilt starts at about 2500!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 12-19-2023, 11:59 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
For what's it worth. I went with a flaming river tilt column in my 67 Firebird. I would recommend keeping the rag joint instead of using their universal however. Other then that I've had zero problems with it. I didn't have to change anything it was a direct drop in. I just had to weld the mounting tabs from the original column so it bolted in like stock.
ID:	625308   Click image for larger version
67 Firebird Convertible
Old 12-20-2023, 12:39 AM
A new Impala tilt is just over $500. I wasn't asking about an original.
Thanks for the info on the Fbird but I have a full size car.
The Following User Says Thank You to Goatracer1 For This Useful Post:
Old 12-22-2023, 10:54 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Where are you finding bolt in Impala tilts for that?
Skip Fix
Old 12-22-2023, 11:29 PM
Ididit website 1961-1962 Impala $558.00 unpainted.
Old 12-23-2023, 03:09 PM
george kujanski's Avatar
Anyone know if the aftermarket stuff has a collapsible column or functionality like a '67 A body?
George
Old 12-23-2023, 08:19 PM
gtospieg gtospieg is offline
Don't know, but I'd be surprised if it didn't have "modern" safety features.
Old 12-23-2023, 10:00 PM
lemans67 lemans67 is offline
They do. I have the tilt from Ididit for a 67 LeMans and I dropped it and sheared the pins for the column. They did send new pins
67 LeMans convertible. Tyrol blue, M22z autogear, 2.73 8.5, 455, FAST MPI fuel injection. 243/ 251 112. solid roller. SD performance ported 6x heads.
