Old 11-11-2009, 01:46 AM
rod cole rod cole is offline
Default Turbo
Where do you find a cheap single turbo for a 455. I want 650 to 700 turbo horse power but the 76 to 88 mm turbos I am finding are all 1100 dollars and up. Are powerstroke or 6.5 or Duramax turbos large enough? Or what salvage or E-bay turbo should I be looking for? Going on a .030 over 6x-8 headed 455 and plan to fab my own piping. While I have the turbo peoples attention on the headers is the heavy pipe nessaary if the turbo is not held up by the pipes. Thanks Rod
Old 11-11-2009, 02:24 AM
Sporter's Avatar
Sporter Sporter is offline
Several places to get new S400 turbos for under $700.
http://www.dallasturbo.com/specials1.html
http://www.turbodaves.com/Products.html
http://www.theturboforums.com/smf/index.php
1967 Firebird ragtop, 464, Weiand 8-71, ported 6H heads, Hyd roller, 4L80E, paddle shifter, Moser 9", Cal-Tracs, Vintage Air, Corbeau seats, 13"/12" disk brakes, Hydraboost, electric cutouts and M&H drag radials.
Old 11-11-2009, 10:23 AM
bankbook's Avatar
bankbook bankbook is offline
PM turbo69bird here on PY he will have the information you need. There is also a good turbo section on PontiacZone.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 11-11-2009, 11:50 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Doc-
Did you get your car out?
John
Old 11-11-2009, 12:19 PM
bankbook's Avatar
No, I hope to have it running tommorow. When I do I will post some pics/video.
DOC'S TA
Both 4 speeds!
Old 11-11-2009, 12:31 PM
Thanks for the links sporter. I have looked on PZ and the info is somewhat confusing. But am learning.
Old 11-11-2009, 05:44 PM
Correct! he can get you good pricing too and make sure you get a turbo thats properly matched. I recently bought a used pair of turbo's for cheap but too small IMO for a 455. I'll need to rebuild one of the turbos as well. I'll be using them on a 360 inch Pontiac.
My advise, if you are just learning turbos is to try to start with a new unit that meets your needs now and has room for more later. Jeff(turbo69) wont steer you wrong! A BW400 can support up to about 700 hp and can be bought for near that number new. There are better choices out there that migh cost a bit more but may be more efficient. BW400's are limited in housing choices.
