Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
Anyone install a Grant steering wheel in an A body?
I got a Challenger wheel for Christmas along with the install kit. Problem is, the wheel wants to be installed with the cancelling cam and horn connection at the 2`oclock position whereas the OEM is at the 10`oclock position.
I doubt if it`ll work correctly at the 2 oclock for cancelling......Grant had 46 years to get this right...what`s the deal? Will it work correctly at the 2 oclock? Doesn`t look like it to me. George
After all these years, This is the first time I've ever seen anyone else mention this problem, so maybe I'm missing something, but the only way that I've ever figured out how to make these work is to install the adapter so that the cam is in the same position as the original, and drill new holes in the wheel. Would love to hear if there is a better fix. |
Whole reason I sold the Grant wheel I bought years ago..... Could never figure out how it installed.... Felt like an idiot.
Troy Rockaway NJ 67 GTO 400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI HOTCHKIS/UMI/BILSTEIN |
Thanks, guys. I`m. Going to call Grant and give them a piece of my mind, but prob going to redrill the thing anyway.
George
Wait .... thats not the reason at all why. The inner our tie rods can be adjusted so the steering wheel will sit correctley by jus installing the whell where it need to be a lot of tghe aftermarket wheeels are off center because there made for so many cars. Thats why on the packages it states you may have to have your alignment adjusted. Not every car make it so the 6-12 are the same amount oof number of splines on the shaft. But it is very easiely fixed.
I would LOVE to hear what Grant has to say about this.
Here's another thread on the same problem:
http://forums.maxperformanceinc.com/...ant+cancel+cam After reading this I remember that on my '67 I just turned the adapter 1/3 of a turn left and used the existing mounting holes, and drilled a new hole for for the horn wire. That would not work on the '65, I had to redrill all 4 holes. Last edited by chipster; 01-06-2013 at 07:08 AM. |
If my memory serves right... I was able to disassemble the wheel and rotate the wheel section to make it work on mine.
The thick CLOUD of tire smoke ,the SMELL of burning rubber,and the CHEER of the crowd ....PRICELESS. $90.00 fine for an awesome burn-out,worth every penny... http://www.youtube.com/watch?v=iI7beXh7xW8 |
OEM wheel in straight ahead position
Here's the OEM wheel, stright ahead, the horn connection MUST be in the 10 o'clock position to cancel left and right turns correctly
Grant hub and steering wheel in recommended install position
Here's the recommended hub and wheel positions
installed per directions
here's what it would look like, straight ahead,, proper cancelling.
grant had only 46 years to get this right........how many people bought their stuff and it didn't fit????? I also have GM '91,'93, and '98 that have the cancelling cam in the SAME position as the '67!! This is with the recommended install kit for a '67 GTO too. i don't get it..... george
Rex....the problem is when it's installed per the instructions (and supplied parts) the right turn signal cancels with the slightest movement whereas a left turn may cancel after a half-turn of the wheel or more. It's just not right. Toget it to cancel correctly, the straight ahead position of the wheel is 90 degrees off. Messing with the tie rods, etc. to get the wheel back to proper straight ahead will ressurect the cancelling issue, plus shorten the turn radius in one direction, and lengthen it in the other. Not the right thing to do.
Make the parts so they fit.....I know it's for a RARE car, a '60's GM "A" body, but get it straight....(pun intended). I'm going to contact them and see what they have to say....... George
Looks like a simple fix. Couldn't you just drill a hole?
Sure,you can redrill, buut it looks like you need to drill all 4 holes, the wheel mounting hole needs to bestraight up. Besides, Grant should haveit designed cqorrectly by now
George
On the wheels Ive installed that center section could be unbolted and turned to any position.
Good luck
Nothing but problems here as well but it was years ago because I swore I'd never use them again in anything other than a farm tractor or boat (no turn signals or horn issues)!
It's shameful that they have yet to fix their age old issues.
___________________________________ "Objects in mirror are closer than they appear" |
On this wheel the center is one piece with the spokes. No turning this one.
George
I sent them an email to their cust. service today along with the pix. Let's see how long it takes for them to respond. If it takes several days, I'll phone them directly.
george
I have a Grant wood wheel on my 66. I turned the cam to the 2 o'clock position, bolted it all together and my signal lights work fine. No redrilled holes at all.
Yeah I know it's not correct and should be at 10 o'clock but it works. I've seen others around here with Grant wheels in their GTOs, and tho I didn't ask I'm sure they didn't drill any new holes. Tho the soonest I can check is in the spring at our first cruise night, and then let you know.
Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
I just came back from my local parts store.... now I'm really cornfused. Grant's website is showing an adapter kit for 66 as 4187, and 3162 for 67.
This is the Grant link for the 3162....... http://www.grantproducts.com/products/view/240/ Funny thing is that all their photos of the kits look the same. To me it looks like really helpful crap. I don't like the looks of this 3196 I have.... if it really is a 3196. Box had been opened and I'm not sure if it's been swapped out and a diffrent hub put in in it's place. Here's the 4187 I already have installed with the 3196 to compare the two....
Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. Last edited by GT182; 01-12-2013 at 11:02 AM. |
