How many cubic inches?
I have a 1972 YS block 400 that was bored 60 over and has a 455 eagle crank and 7K3 heads.
I was wondering what the cubic inches would be. Thanks |
You would have a 462 cid motor.
57.77 cid per cylinder. Basically you now have a .030” over 455. The heads you have on it have nothing to do with CID.
I do stuff for reasons. |
The Following 2 Users Say Thank You to 25stevem For This Useful Post: | ||
Thanks,
462 cubic inches . When people ask I never know what to say without going through the whole build. |
Wallaceracing.com
One cylinder cu. in. = bore x bore x stroke x .7854.
4.21 stroke or 4.25 ?
Not sure about the stroke.
In opening post you indicated 455 Eagle crank- where did you get that info?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
I would just tell everyone it's a real strong 400 ci with lots of torque. You are running an experimental cam.
just a thought! Jim
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
The Following User Says Thank You to Jim Moshier For This Useful Post: | ||
Pontiac Dude out of Brooksville FL told me. He built the engine for me. On the receipt it stated eagle 455 crank.
As eluded to here in this thread Eagle makes two Cast Steel Crankshafts for a 455, a 4.210 stroke and a 4.250 stroke.
Does the receipt state what kind of rods and pistons are in it? Typically 4.25 stroke setups will use 6.8 Chevy rod and 4.21 stroke would use 6.625 Pontiac rod.
Might help narrow it down? |
Pretty sure 4.21. when I get home I'll check the receipt. Thanks
Thanks, I'll check the receipt when I get off work.
We putting 3.25 main cranks in 3.00 blocks now?
Most of the Eagle cranks were 3" mains to fit in the 400 block.
(both 4.21" stroke and 4.25" stroke)
lol
Mine is 4.25 stroke eagle with pontiac size rods
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) Last edited by jonmachota78; 01-21-2023 at 07:59 PM. |
So after further review...not an eagle crank. You can see from the pic that it is a Pontiac 455 crank cut fior a 400 block using "Custom Dude" main bearing conversion kit.
I haven't looked at this receipt in years and guess when I read the footnote under the crank part where it says " Eagle cranks might require extra Mallory to balance" I wrongly committed to memory that it was an Eagle crank. Wishful thinking I guess. Anyway, by looking at receipt, it appears he used the original 400 rods Crane XE268H cam Maybe this new information will help determine my cubic inches. Thanks for all the responses. |
