Old 01-21-2023, 08:04 PM
Jimbobeast Jimbobeast is offline
Default Power seat back solenoid
Anyone know where this solenoid for the 1970 Power Seat Back Release option should be mounted? I'm guessing under the console, since it will have to connect with both seat backs, and it looks like there are some dimples in that area that seem to make sense.
I've finally gotten the PDL, PW, Power Top, Power Flow Through ventilation and Power trunk release harnesses all sorted and installed.
Also, in 1970, did the 8-Track option mandate a rear speaker, or could it be ordered with the front speaker only?
ID:	605703   Click image for larger version
Old 01-21-2023, 10:17 PM
gto4evr gto4evr is offline
it mounts under the driver's seat. roughly in the middle. there are dimples in the floor for the self tapper screws. I've only got one garbage picture of it before I replaced my floor pans but it's to the inboard side of the ribbon cable channel. your short wire goes to the driver's side seat, then the long one goes up and over the tunnel to the passenger seat
Old 01-22-2023, 06:57 PM
My bad, it's the relay, not the solenoid, but the advice from Ultimate Warrior was spot on. I found dimples in kinda the right spot described above although they did not fit the relay mounting holes exactly. In any case it's in and 99% of my electrical stuff is done. Thanks.
ID:	605773   Click image for larger version
ID:	605774   Click image for larger version
ID:	605775   Click image for larger version
The Following User Says Thank You to Jimbobeast For This Useful Post:
