Rear Sway bar location
I realize they didn't put the rear sway bars on until 70' but I would like to add one to my 69' 350 H.O. Lemans and I was wondering if there is a template available for locating the placement of the holes in the trailing arms so I can put them in before I weld in the inserts, or if someone would be so kind as to let me know what those measurements should be it would be Greatly appreciated.
Thank you
NEVER DRINK DOWN STREAM FROM THE HERD |
Lower boxed control arms were used from factory to bolt the swaybar to. 2 bolts per side
I should have some boxed arms to measure.
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
that would be great! thank you!!
Hope this helps
Sent from my Moto Z3 Play using Tapatalk
The instructions for the Summit rear sway bar have measurements.
https://static.summitracing.com/glob...sum-720208.pdf
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
[QUOTE=thepontiacman;6403904]Hope this helps
indeed it does and I thank you very much!!
[QUOTE=Verdoro 68;6403928]The instructions for the Summit rear sway bar have measurements.
Thank you Verdoro 68 (Verdoro Green hands down my favorite Pontiac color!! ) for the heads up on that I will save that in my files
