Old 01-29-2023, 03:40 PM
goatboy1970 goatboy1970 is offline
Default Head Bolt Length
Someone swapped out the stud head bolt where the negative battery cable attaches and I'm replacing it. Ames has 3 different lengths. What's the correct head bolt length here? #13 heads, first cylinder on driver's side for reference.
1970 GTO I Pepper Green, YS Code, numbers matching, PHS documented
Old 01-29-2023, 04:20 PM
It should be about 3/4” longer than the head casting where the bolt goes through. Your measuring tape will tell you which length to purchase.
Old 01-29-2023, 04:31 PM
Car is at paint and I won't have it back for a few months. Was hoping to order the part to be ready when it gets back.
Old 01-29-2023, 06:32 PM
3 5/8" version on modern Dports in that position.
Old 01-29-2023, 06:49 PM
Thank you, friend.
