SOLD Pontiacs The cars in here have already been sold. The topics will be kept for a few months for referance. |
1973 Ventura
Finally decided to sell the Ventura as it hasn't been on the street or at the track now in nearly 2 years.
Stroked 428 four bolt main block to 455 CID, KRE aluminum heads from Dave at SD, makes more power than you could ever use, but very mild at a glance. No expense spared in the engine, transmission and diff/suspension. Can be driven anywhere and will run nearly into the 10's in full street trim thru the mufflers by simply lowering the tires pressure to 18psi, don't even have to shut it off or cool it down. Dead solid reliable and turn key mechanically other than needing a new set of DOT's. Frame is rock solid, nothing more than a little surface rust in a few places. Hasn't seen water other than from washing it in over 30 years. Body could use a little work, interior is rough. Still looks good and runs even better. Getting out of the car thing and moving on to other adventures. $15,000 firm, no trades, serious inquiries only. Can send pics or can be seen in Mount Vernon Ohio 43050. https://www.youtube.com/watch?v=8U9iDTv3zj4 https://www.youtube.com/watch?v=6zVdoLR-VzM&t=21s PM or call me at the shop: 740-397-2921
WTH has Cliff been hacked?
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
Retired in April so downsizing some. I'll keep the business till it sells or I completely retire. Right now I'm still open but mostly selling parts. The business is also for sale, have a few folks looking at it but not much more than that.......
I wish i had the money, this would be a dream car for me to own.
bump.
It's still here and needs a good home....
Cliff!! You're back!!
Today is a good day.
1970 GTO (Granada Gold) - 400 / TH400 |
PM sent
PM sent
