Old 01-25-2022, 01:41 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Default 1971 - 72 Grand Prix Rear Seat - Trunk Divider Insulation
Looking for a photo of an original '71 - '72 rear seat/trunk divider insulation in place with the rear seat removed.
Thanks,
Grant
Old 01-29-2022, 04:48 PM
ssj71's Avatar
ssj71 ssj71 is offline
Grant, I would imagine my 71 has this intact and undisturbed.
Are you looking for its exact factory position?
1970 SSJ: 272
1971 SSJ: 157
1972 SSJ: somewhere between 60 and 350...
Old 01-29-2022, 05:17 PM
428ho4spd's Avatar
Harvey... I thought of your car, but I didn't want to put you through the trouble to remove both seats just to get a photo.
I'm going to replace the current thin hard cardboard type that was installed during the restoration with a more correct soft padded style like they originally had. The one I bought is listed for a GTO and requires cutting around the vapor tube area so I wanted to compare the two before installing it if possible.
Thanks,
Grant
Old 01-29-2022, 05:24 PM
ssj71's Avatar
I wouldn't be opposed to yanking that rear seat out for some detailed pictures...
1970 SSJ: 272
1971 SSJ: 157
Old 01-29-2022, 05:28 PM
428ho4spd's Avatar
Thanks, Buddy... that would be greatly appreciated, as always!
Old 01-29-2022, 06:44 PM
ssj71's Avatar
I'll get you some pix in a couple of weeks when I'm back in Tampa.
1970 SSJ: 272
1971 SSJ: 157
Old 01-29-2022, 07:17 PM
428ho4spd's Avatar
Sounds great, thank you!
Old 03-10-2022, 08:18 PM
428ho4spd's Avatar
Default Update
For you '69 to '72 GP owners needing to replace your rear seat divider, this "soft" padded style listed for the '68 - '72 GTO worked out great. Ames part #K161F, it's very close to the original GP version. I only had to cut two horizontal slits in it for the hooks/hangers that holds it in place. And for my '71, I did not have to modify it for the vertical vapor canister, it simply lays over it.
https://secure.amesperf.com/qilan/De...A&web_access=Y
Thanks again to Harvey (ssj71) for his helpful photos.
Grant
ID:	585864   Click image for larger version
ID:	585865   Click image for larger version
