Old 04-20-2021, 12:17 AM
65sport 65sport is offline
Default Power antenna
I have an early production 65 Lemans with a lot of options. It has a power antenna coming out at an angle on the RR between the trunk and the quarter panel, factory with the factory switch on the dash.
I can hear the motor running with the switch on up or down, but no movement on the mast. I can pull the antenna up and down only a few inches. I expect I need the nylon insert that goes inside to move the mast.
Or maybe a gear ?
I haven't been able to find any parts, so hoping I can fix the original.
Old 04-20-2021, 10:48 AM
BOB VIDAN BOB VIDAN is offline
If you run the switch and hear a clicking in the motor, sounds like the nylon is frozen. Most likely you'll have to replace the mast w/nylon. There are not easy to find and expensive when you do.
Practicing social distancing for 65+ years
Old 04-20-2021, 05:07 PM
tempest1964's Avatar
There is a guy in the Tampa Bay Area. I believe he refurbishes them. I bought one from him. It was excellent. He might be able to do something for yours. His name is Frank and he is a member here. I can’t remember his user name. You can PM me if you would like his contact info.
Old 04-20-2021, 05:12 PM
No clicking sound, just the motor running. Up or down just the motor running.
Old 04-25-2021, 03:25 AM
james66GTO james66GTO is offline
Default Power Antenna
I believe the part number for the correct mast for an A body is 541963. A lot of people run the longer B body masts because they’re a little easier to come by Eric
Old 01-23-2022, 11:06 AM
tallrandyb's Avatar
tallrandyb tallrandyb is offline
Question
Can you tell me the proper extended height for the 65 GTO? I have a power antenna installed and when it extends it is taller than I expected.
I can look for the part number on the antenna body.
Thanks!
Old 01-23-2022, 07:02 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Thanks!
The OEM electric antenna on a 1965 GTO extends 54’’.
Careful going under low bridges.
Old 01-24-2022, 02:09 PM
tallrandyb's Avatar
That's got to be it then. I was very surprised when it kept going and going! Thanks.
Old 02-09-2022, 01:30 PM
GT182's Avatar
GT182 GT182 is offline
Yeah he knows his stuff for antennas. I bought my rebuilt 66 power antenna from him a few years ago and it's still working.
His number is 352-688-8199.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
