Old 09-03-2021, 03:55 PM
tekuhn tekuhn is offline
Default '63 Clock Installation
I wonder if anyone has a picture, or perhaps the bracket itself, used to attach the instrument cluster to the dash when there is a clock installed in the rightmost pod instead of a blank face? The blank face bracket does not clear the back of the clock, so I assume there is either a different bracket, or the clock itself should have a mounting stud installed in the rear cover. If it's a separate bracket, perhaps it's also the same one used when a tachometer is installed?
The clock I restored was taken from a '64 LeMans cluster, and it fits perfectly, but perhaps it is missing the mounting stud if the '63 used one.
ID:	572384   Click image for larger version
ID:	572385   Click image for larger version
Hoping to finish a project while I'm still able to push the clutch in....
1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures
Old 09-03-2021, 06:28 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default 63 Lemans Clock
The 63 Lemans clock has a rear case similar to a 64 except it has a giant stand-off with a threaded stud made into the back of the housing.
The 63 Lemans clock would be a clock specific to that one year. The '63 second hand and hour numerals are bolder and wider than the '64 or newer A body Pontiac clock.
Name:	63Lemans in-dash Clock_1.jpg
ID:	572394   Click image for larger version
Name:	63Lemans in-dash Clock_2.jpg
ID:	572396   Click image for larger version
Name:	63Lemans in-dash Clock_3.jpg
Peter Serio
Owner, Precision Pontiac
Old 09-03-2021, 06:57 PM
Thank you- exactly what I needed to know. I will add the stud to the back of my ‘64 clock rear cover.
Did the ‘63 factory tachometer also have a stud on the back since it went in the same location?
Old 09-04-2021, 11:21 AM
Default 63 Lemans Tachometer
You are correct, the '63 Lemans tach had that same mounting stud on the back of the case.
The '63 tach came in 2 different versions; one for a 4 cyl car and one for a V8, (both would have been for a points distributor).
The 64 tach came in 3 versions: 6 cyl, V8 with points distributor and V8 for a car with the Delco transistor ignition option, (very rare).
Name:	63Lemans in-dash Tachometer_1.jpg
ID:	572423   Click image for larger version
Name:	63Lemans in-dash Tachometer_2.jpg
ID:	572424   Click image for larger version
Name:	63Lemans in-dash Tachometer_3.jpg
Peter Serio
Old 09-04-2021, 09:33 PM
Thank you, Peter! The short rib on the cases makes it pretty easy to see where to drill for the stud. I hope to have mine installed tonight.
Maybe you could answer another question for me? I’m thinking about adding the ‘65 Ralley Gauges, but hesitate because they have a black background instead of the blue. My radio has the blue background. Is the ‘66-‘67 background color any closer to correct?
Old 09-04-2021, 09:40 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
There's no place to put the stud on 65 gauges, thats where the oil and temp gauges are
Old 09-04-2021, 09:45 PM
The 66-67 version of Lemans/GTO rally gauges would be a closer match to your radio color but you will run into clearance issues with the mounting vs the wiring plug-ins for rally gauges.
There was never any gauge option available for '63 Lemans due in-large part to the way the bezel mounts into the steel dash. The steel is housing is also where the gauges get their ground to transfer over & into the car body. Via those 2 mounting studs on the back of the housing.
Peter Serio
Old 09-04-2021, 11:38 PM
Ah - good point. Looks like those are the repro gauges in a '63 dash? Did you fabricate another way to secure that corner, or just go with 3 attachment points?
Old 09-04-2021, 11:41 PM
Originally Posted by Peter Serio View Post
......... The steel is housing is also where the gauges get their ground to transfer over & into the car body. Via those 2 mounting studs on the back of the housing.
Even with this clock installation, I went ahead and used a socket with a ground wire for one of the illumination lamps to make sure the clock body was well grounded.
Old 09-05-2021, 12:55 PM
hobbygto65's Avatar
No haven't decided on that yet, maybe just a screw through bottom below the gauge into the dash frame. Here's what front looks like.
ID:	572539   Click image for larger version
ID:	572540   Click image for larger version
Old 09-05-2021, 03:06 PM
I like that. Look nice!
