Replacing the fruit jar on a 64 grand prix
Hi all:
I'm new to this car and I want to keep the power drum brakes but not the single circuit master cylinder. What dual circuit master cylinder will work with the factory booster and drums? Thanks all, Mario64 |
I think in general people use a dual master cylinder from a 1967-1969 full size Pontiac, but there are others that may work. Here is an old discussion about that conversion: https://forums.maxperformanceinc.com...d.php?t=641491
It takes considerable knowledge just to realize the extent of your own ignorance. Dr. Thomas Sowell |
I hope what ever you do does well.Have a couple friends that have done them and were very dissatisfied with results and took some major effort to get resolved.I have just stayed with the single because of it.Tom
I want to thank all of you that took the time to reply.
I have installed the scarebird conversion on my buddy's 66 Olds. That used front discs and a Buick wagon disc/drum master. I ran the lines like mentioned in the first post. Front port to the line to the distribution block. Then on to the front brakes and a barrel connector from the rear port to the rear brakes. That was my second scarebird kit. The first one on my 68 Deville. I used a 9" booster and a vette style master. Both operate flawlessly. My question stems from a drum/drum install, unlike the other which were disc/drum. I will post results when done, probably a few weekends. Thanks again. Mario64 |
I used a master from a 1967 full size Pontiac on my 1964 GP. It work well with no problems.
To be clear,the 2 cars that had issue were 8 lug cars and were only changed to a dual master,no brake changes at all.Tom
that is an interesting observation. are the two cars you are referencing manual or power brakes? and why would it make a difference between the five lug drums or the eight lug drums? thank you. mario64 |
They were both power brakes.Not sure if the 8 lugs had anything to do with it.Just wanted to make it clear there was no brake changes like going to disc somewhere.Tom
Thank you. Will update when brake job is complete.
Mario64 |
I would use a mid 60s Cadillac master as the outlets are on the other side, which makes it easier to plumb it.
Mario64 |
Master power brakes makes a booster master combo works perfect in those cars
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
