Old 12-31-2021, 08:13 PM
beerslob beerslob is offline
Default formula ram air air cleaner
wanted ram air air cleaner for 72 formula i would be interested in 71-75 if theres one for sale. thanks, tony
Old 01-01-2022, 12:28 AM
Ramairnacho Ramairnacho is offline
Default 1972 air cleaner
Hi Tony
I'm Ignacio hapoy new years
Im.alao looking for an air cleaner mine being 70, I have a 73 that I might trade not sure yet. I'm on vacation, I learned 71 72 had 2 heat risers on botom.and 70,73-75 only had 1 the 70 bowl is bigger requiring a bigger air cleaner. There are restamps or repops available too. If you run across a 70 let me know and if I buy one I'll sell you my 73. I'm new to site. If your not concerned with heat stove or factory correct stuff buy a repip from parts palace they only 399 new and it's a 74 bowl base
Old 01-01-2022, 11:32 AM
thanks for the info, i wasnt sure of what was different on them, are the repos a decent part? i would rather have a gm part but not to worried about the year... thanks for reply
Old 01-01-2022, 01:44 PM
The 1971 & 1972 air cleaners with two heat risers on the bottom were only used on the 455HO engines, which are round ports. I'm pretty sure ram air was an option on the D-port motors, which only had one heat riser.
The Following User Says Thank You to poncho-mike For This Useful Post:
Old 01-01-2022, 01:50 PM
Default Repop air cleaner
Im.not sure on the repop reviews but by direct from The parts Place go on web site. They sell the whole kit with boots and brackets . You have choices too. If you want heatvstove riser vent fir warming up car or not. You can also ask in our section on formula cars. I haven't head of them failing so I think they are good. If your set on an original they might be more expensive than repop but I'm not 100 sure. I seen a 74 nos for 1200 a few months ago. And another nos for 2500. IF YOU WANT GENUIM GM ILL LOOK INTO IT FOR YOU.
