Old 01-01-2022, 02:45 AM
Jc73driver Jc73driver is offline
Default 77 Firebird rotisserie mounting
I’m about to put the body of my 77 TransAm on the rotisserie and wanted to know what the best pivot point reference would be for the Firebird. I’m looking for the best reference to position the body to the pivot axis on the rotisserie so it rotates freely. Thanks for any advice or recommendation.
Jim
Old 01-01-2022, 04:56 PM
400 4spd.'s Avatar
Here are two F bodies that we had mounted at different times. Regardless of where your attaching points are on the car (do not have to be same height), you want to keep your front and rear pivots at matching heights.
ID:	581148   Click image for larger version
The Following User Says Thank You to 400 4spd. For This Useful Post:
Old 01-02-2022, 11:11 AM
Big Bear's Avatar
Big Bear Big Bear is offline
Raise it high enough to clear the lower bar.
ID:	581176   Click image for larger version
The Following User Says Thank You to Big Bear For This Useful Post:
Old 01-03-2022, 10:22 AM
TAKerry TAKerry is offline
My settup is close to Big Bear's. Only I added a long ram jack at each post to make moving the body up and down easy.
Old 01-03-2022, 02:11 PM
Formulabruce's Avatar
Use a flat plate on back where bumper bolts if thats all good, if not, fix it first so you can use it. . Use a mid point in front about half way up the firewall.
The Actual center for rotation is about where your trunk lock is in rear and at the transmission tunnel top edge on firewall in the front.
It can spin doing it a little lower, but as has been said by BIG BEAR, gotta miss the lower bar..
