Old 01-02-2022, 06:45 PM
Scott Thelander's Avatar
Default 7038140 throttle base plate ID
7038140 base plate...
I thought this was off a 7029268 but my book only shows
a
7038139
any help out there ????
Scott
ID:	581254   Click image for larger version
Old 01-03-2022, 01:24 AM
unruhjonny's Avatar
those books can confuse;
I have understood that those numbers are an assigned number for a finished assembly.
I have that number recorded in my own file as being for a 7040564
Maybe that helps
1970 Formula 400
Old 01-04-2022, 01:32 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Scott... that appears to be a '71 baseplate going by the throttle bracket and vacuum fitting in the front.
Grant
ID:	581357   Click image for larger version
Old 01-04-2022, 01:40 PM
428ho4spd's Avatar
Looks like '70 with CA emissions also used that style baseplate.
Old 01-04-2022, 03:10 PM
Kenth's Avatar
Kenth Kenth is offline
I have found the #7038140 throttle plate was used on 1970 California Quadrajets only.
RamAir units has .123" holes in the throttle blades, .072" idle bypass air and shorter off idle slots than non-RA units.
Non-RA units has .093" idle bypass air and intact throttle blades.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-08-2022, 06:31 PM
THANK you Guys !!
another fishing weight ,,,,,
Scott
Old 01-08-2022, 08:07 PM
OG68 OG68 is offline
Fishing for Columbia River Salmon again Scott?
2007 Cadillac SRX
Old 01-08-2022, 11:25 PM
unruhjonny's Avatar
a fishing weight?
if you don't want it, i'll take it.
1970 Formula 400
