Old 01-04-2022, 09:21 PM
mrennie's Avatar
mrennie mrennie is offline
Default Looking for tips & tricks on drip rail and window molding installation 70 GTO
Hello,
Any tips on reinstalling the drip rail moldings? They are super thin and easy to dent, and I recall them being a PITA to remove many years ago. I tried my best to limit how much paint the actual drip rail received so that wouldn't cause problems. Would applying a small film of grease or WD40 help them roll on?
Also looking for advice on reinstalling the 4 molding pieces for the back window. Is there a certain piece I should start with, or an order to install them? Do I just snap a few of the retaining clips and get all 4 moldings mated and then finish locking them down or ???
Thanks!
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Old 01-09-2022, 11:07 PM
1965gp 1965gp is offline
I think the reproduction drip rails are thin enough you can put them on by hand.
As for the rear window I put all of the clips in, then assemble the trim as one piece and slowly work the trim into the clips.
The Following User Says Thank You to 1965gp For This Useful Post:
Old 01-10-2022, 11:43 AM
78w72 78w72 is offline
window moldings should install very easy, all ive ever done on 2nd gen birds is use the palm of my hand & gently push right at the clips, it should click down with not much pressure.
removing them with the right tool can be scary but they usually pop right off once you learn how to use the tool at the right angle, some tools are better than others so dont buy a cheap one.
Old 01-10-2022, 03:57 PM
Buck Wilde Buck Wilde is offline
With the drip rail moldings, i sometimes open them up a little on the underside lip and them roll them on from top to bottom with a light tap of my fist to get them over the bottom edge. If they are loose, you can crimp/ tighten them the underside by pressing from underneath with a straight slot screw driver. Never used any grease. They are pretty easy to distort.
