Old 01-23-2022, 09:26 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Default Flywheel Bolt Question
On a manual transmission 2nd gen (Pontiac V-8)......were there external tooth lock washers on the flywheel to crank bolts from the factory?
The Pioneer replacements bolts come with them...
Old 01-24-2022, 08:25 PM
Formulabruce's Avatar
Have never seen any on the 70, 71, 72 and 73 cars I have had apart. I believe I was the first guy in there.
Old 01-24-2022, 11:39 PM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
Not a lot of room in there. On my application, the ARP bolt heads were too thick, I needed to find original bolts or they hit the clutch disk hub. No way there was room for washers.
Probably me but worth the mention….
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 01-26-2022, 10:40 PM
Hmmm......guess that explains the shiny spots....on what I believe to be my original bolts....
Old 01-27-2022, 10:39 AM
78w72 78w72 is offline
my 78 t/a didnt have washers either, just re-used the stock bolts on a new clutch.
Old 01-27-2022, 12:19 PM
FrankieT/A's Avatar
The Mr. Gasket bolts should work fine. Their heads are thinner than ARP. Clutch disc spring contact is always an issue.
Old 01-28-2022, 10:09 AM
chuckies76ta's Avatar
I'll throw my .02 in. I used Pontiac ARP bolts on one of my clutch setups and the bolt heads contacted the clutch disc. I found ARP bolts that were for Chrysler flywheel and the bolt heads were thinner.
https://www.summitracing.com/parts/a.../make/chrysler
