#41
When the block was tanked, was it also magged/sonic checked?
#42
Howdy former neighbor!
What did you put in the water pump holes to keep the fill material from running out while you filled it about 1/3 of the way up the holes?
"Nothing Beats an Ol' Goat." |
#43
I just put duct tape on the outside of the opening. Then while it was setting up still not completely hard, in the back I scaped off the excess material to make room for the freeze plugs, and in the front, I removed some material so as not to restrict water flow to and from the water pump, made kind of a gradual transition.
Tim Corcoran |
#44
I had it sonic tested before I had it hot tanked but I did not have it magged
Tim Corcoran |
#45
This engine should have been to the machine shop two weeks ago, but I was not comfortable with the amount of dowel pin engagement. I had to locate some correct size pins, I didn't want to go oversize pins as that would require reaming the block and the caps. I finally found the correct size dowels and got them installed today. There is only one company I could find that provides the longer factory size dowel pins for a Pontiac (Precision Automotive Specialists). While installing the caps I was going over the surface with a small stone to remove any burrs that may be present and found cracks around the dowel pin hole in the rear main cap. Not too happy about it but sure glad I found it. Now I need to get a new rear main cap.
Tim Corcoran |
#46
Dang that sux. Sorry bud.
#47
I probably have a rear main cap for 3in
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
#48
you got lucky on reusing your cam, when my rod broke piece went up into it and bent the camshaft.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
#49
I might be confusing some people who are following my posts as I have two projects going on. The 455 engine that had a catastrophic failure at Norwalk, I am building a new engine to replace it, a 400 stroker (4.25 stroke) for my 65 LeMans drag car. My street car (67 LeMans) that is also a 400 stroker but with a 4.00" stroke is a fresh engine and this is the one that has the number 3 misfire. I will be pulling the head today to get that car back on the road.
Tim Corcoran |
#50
I got a new rear cap thanks to Paul K. All new dowel pins installed, and I took it to the machine shop today to get line bored, cylinders bored and decked. After that heads will be milled to bring compression up a bit.
Tim Corcoran |
The Following User Says Thank You to Tim Corcoran For This Useful Post: | ||
#51
How much can ported E-Heads be safely milled?
Tim Corcoran |
#52
I went a .100 thou on an 87cc head to get to 72cc no problems
after 15-20 years still useing them GT |
#53
Mine are currently 91/92cc I'd like to get them down to around 80 or a little less. When you milled yours did you have much left to seal the top of the valve cover?
Tim Corcoran |
#54
A lot, the deck is 5/8 thick. We've milled 87 cc versions to 69 and know one guy that went to 65 cc. Two things to remember;
When you mill the head excessively you loose V to P clearance fast. Also, you'll start to loose radial valve to pocket clearance. So if your using say a 2.19 valve, you may need a pocket designed for a 2.25 valve. |
Thread Tools | |
Display Modes | |
