#401
I just asked my cousin (has a 71 TA with a power release trunk);
He’s out of town right now, but his recollection is that the button on his car is yellow.
#402
1970 One year only parts
I have an original low mile 1971 Trans Am and the power trunk release button is green. The car is a 05B dated Norwood build. Sent from my iPhone using Tapatalk |
The Following 2 Users Say Thank You to Uncle Judge For This Useful Post: | ||
#403
ok, so this begs the question;
Were there blue buttons used for the trunk release in "1970+" Firebirds? When was the change from green to yellow?
#404
Blue buttons....no
Over the years some folks have ask for in orders or mentioned on boards a GREEN release button (the actual med green color) when the actual color is the slight greenish turquoise color.
For the different GM divisions in the late 60's through early 70's each division still had a lot of autonomy, & each division sourced their own trunk release buttons. This was ESP true for '70 & 71 models. From decade after decade after decade of pulling & offering desirable parts & chasing specialty core parts, rescuing cars, dragging in partscars, & examining in collections many fine GM musclecars of the era, there are at least 5 different style small diameter trunk buttons. All used basically the same recessed center tip button. Buick : '70 model & have pulled several from '71's. Black housing, Red button... to me has been one of the tougher to find versions. Chevrolet: 1970, black housing, med green, have pulled near a dozen, all from Caprices & MonteCarlos. Have yet to pull an original one from a '70 or 71 Chevelle or Camaro but have examined highly detailed original cars with them. There were also over the counter Chevrolet accessory pkg's sold with this color of button, as I've owned & sold two such pkgs & have examined several more. Olds: the flat chrome plated rectangular plastic postage stamp size switches, embossed trunk release, black button. Though different design outer area, the black button is same size. Not an easy button to remove for the newbie in yards. Solved that problem in the mid 80's. PONTIAC : confirmed on many very original '70 Pontiacs, all body lines. Dk greenish turquoisish color, used up into mid 74 model year. Been pulling & stocking trunk release options of this style since 1982. Dairable options are one of the segments that I loaded up on decades ago when it was like a kid in a candy store. During major boneyard trips with tight time lines, often I just pulled the original switch, the clips, & either one piece or two piece trunk release in the back. On '71- mid 74 Pontiac big cars, normally just pulled the buttons & clips. The '71-76 big Pontiac trunk release is a very slow seller. In yard visits with time to burn, have pulled jumper harnesses & main line harnesses. "Corporate button" Small diameter yellow button (common as dirt). Was avail at local GM dealers forever. Included in many accessory pkg trunk release kits. National catalogue joints like Year1 offered these buttons for sale for over 20 years. Not used on original '67-72 A-body's, F-body's etc. Original use was mid '74 through at least '80 models. Eventually the larger diam yellow buttons began to go in every thing GM from the 80's-90's GM crusherbait years. The mystery button. Small diameter with black button. Outer round housing is chrome plated plastic. Same exact button as most above. First style GM electric trunk release button... the black long bubble style button that the outer hsg is threaded & requires jamb nuts or a cup shaped protective shroud type housing like used in '69 GP consoles. On several other late '60's GM, used w/o a shroud.
Buzzards gotta eat... same as worms. Last edited by 'ol Pinion head; 06-26-2023 at 12:52 PM. |
The Following 2 Users Say Thank You to 'ol Pinion head For This Useful Post: | ||
#405
thank you for the very clear answer!
I will remember to remove this from a "1970 only" part, to maybe an 'honourable mention' incase anyone asks about it AFTER reading the thread
#406
Hmmm... https://forums.maxperformanceinc.com...d.php?t=727640
So long, farewell. |
The Following User Says Thank You to Held for Ransom For This Useful Post: | ||
#407
that last link was awesome! - it even gave a picture!
I have been slowly picking at an updated comprehensive list, and looking for already hosted images to link for the updated post; This item has been moved to 'honorable mention' status.
#408
If you had a dealer install one in 71, Green button, newer style release mechanism in trunk.
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather Last edited by Formulabruce; 06-26-2023 at 05:54 PM. |
#409
None of the original greenish turquoise buttons that I have appear that blue.
Have the original dash assembly out of an Oct 69 Baltimore built GTO awaiting trip to Al Knoch. Its button is same shade as the original button in my HO T-37 Coupe built 14 months later. The latter is a 31 option car & the harness & button are the same that was in the car 33 years ago when it came up from Texas. Several years ago strategically cut up a rustfree April 71 Atlanta built GrandPrix. Had a bad frame from a prev front end wreck. It still has its original greenish turquoise trunk release button in the console box. After I pulled that GP's rebuilt YS engine, I had to jump the console mounted switch connection with a battery to pop the trunk. Back decades ago I hauled 9.6 Makita tools. a fully charged 9.6 Makita battery would normally pop a trunklid the same way.
Buzzards gotta eat... same as worms. Last edited by 'ol Pinion head; 06-26-2023 at 06:13 PM. |
The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
#410
#411
IIRC the change over most see is in more luxurious cars. That said, the new yellow button that showed up in those cars is bigger..
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
#412
Let's END the " Blue" " mystery " . The " blue" pic in the other thread posted by Greggggg is clearly a painted switch and clearly matches the blue paint on that section of dash that the green switch is in.
I am positive Gregg didn't paint that as his OCD would be acting up!! I can say from my experience that I never saw a Pontiac Dealer kit for a f body dated from 71 and up to have a Green button. This does Not conflict with OPH . We installed a bunch, and when we didn't have a F body kit, we used the Bigger yellow buttons from big car kits, in Firebirds. Yes they fit fine, just make a bigger hole. Ordered the release , used our in house black ground, and a standard fuse box power lead. The yellow small and large are far more common as OPH says. The release is inside the glove box for Valet reasons. Over the years many have sold open kits with miss matched parts and claim they are for a F body. Most are Not. Kits for Le Mans , Catalina, Bonney's etc were Much more common.
The Following User Says Thank You to Formulabruce For This Useful Post: | ||
#413
Haven't gone back and reviewed the whole list,...but is the one year only Van Nuys built California emissions NA9 gas tank on there?
#414
Norwood built many Birds that were " exported" to California, with EEC . I assume they had the 3 hole gas tank too
#415
Here is a much delayed update, I have some points with "?" which require collaboration from you all to help me explain this further.
I will seperate the sections by making them seperate posts. Sheetmetal and/or panels:
#417
Exterior/trim:
#418
Interior:
#419
Underhood/engine/drivetrain:
#420
1970 & 1971-only parts:
