#41
I'm using a SIMMS unit. You won't save money on it though. Not even sure they're still available.
#42
Some of these guys would be a real ball at parties eh? |
#43
Pontiac used 2 different oil pump drive shafts, the stronger one were used for O-port engines.
D-port #534652, O-port #9794305. |
#44
Driving down the road, and all of a sudden the lifters start clattering - that is a BAD feeling, even more so when it is in your daily driver.
That is what I experienced about 26 years ago, when I reused the oil pump driveshaft on a rebuild, and it broke about a year later. I have not reused an old shaft since then. CHEAP insurance against an easily avoidable failure.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
#45
And when going out to dinner avoid drinking expensive ice tea for a week or so and one can cover the shipping costs on the nice billet piece
#46
I have the sense that the "crappy" OEM driveshaft is the outlier, while the "HP" OEM shaft, the Melling, and the bling-y "billet" shafts are all functionally equivalent (i.e., they all work about the same.)
#47
once when priming an oil pump with an old screw driver and a drill I was unable to get the distributor in after. I had accidently spread the ears apart on the driveshaft. I managed to squeeze them back together and never failed but I probably just got lucky.
69 Firebird, 462 turbo 400 3000 stall, 8.5 323 rear |
#48
Hehehe ... the old "squeeze the ears" trick ... that is truly living on the edge there
I forget where I got mine, but I think it was black and kind of shiny, think I got it from Butler. |
#49
Then there are folks who stress over an oil pump driveshaft bending, twisting or breaking so they buy a hardened one and then drive it with a polymer dist. gear.
___________________________________ "Objects in mirror are closer than they appear" |
#50
Stress proof is an excellent steel for oil pump drive shafts. Google it.
H-O oil pump driveshaft failures: We sourced RA4 driveshafts from GM and they forgot (?) to heat treat them. Unfortunately , some customers had driveshaft failures. We notified every customer who bought one and replaced every one, if the customer responded . It was at this time that we started making our own OS-11 shafts.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
#51
I have to use a polymer gear because I am using a roller cam
#52
Yep that's pretty typical. 3 polymers here, no issues with those and I've been running something with a roller for close to 20 years. Can't say the same for oil pump shafts. Probably has a lot to do with the strength of the helicoil cut gears verses a couple of ears sticking out of a shaft.
#53
Agree, not related. I've never had a issue with the BOP poly gear with a 80 lb oil pump. Many others report similar.
Onward. .
#54
I had one break, it cost me a 463 motor, not again.
