Old 07-09-2022, 03:02 PM
hutchwareltd's Avatar
hutchwareltd hutchwareltd is offline
Question Part Identification Help
Help needed to identify this part. Anyone know what this bracket is?
Thank you.
ID:	593974   Click image for larger version
Old 07-09-2022, 05:05 PM
I have one like it on my 1967 GTO. It is mounted across the dash opening where the steering column fits up. It is under the column going from one side of the opening to the other.
Old 07-09-2022, 06:17 PM
Jeff Hamlin's Avatar
Goes across the top of the driver-side lap vent on models with AC;
Old 07-09-2022, 07:25 PM
jhnichols2 jhnichols2 is offline
Can you provide some dimensions? My 67 is missing this piece and I would like to try and fabricate one. Right now I just have a flat piece screwed to the under dash to mount the air deflector. Thanks.
Old 07-09-2022, 07:44 PM
gto4ben gto4ben is offline
The pictures you provided appear to be the correct for 67 with AC & 8-track DS lap vent bracket 9788984. Compare the relative length with the AC only DS lap vent bracket 9787826. Attached are some dimensions of the AC only version to help guide you fabricating one for AC & 8-track.
Name:	Comparison of AC only to AC & 8-track DS vent bracket.jpg
ID:	593992   Click image for larger version
ID:	593993   Click image for larger version
Old 07-10-2022, 06:34 AM
Thumbs up GOOD TO KNOW
Something I wasn't aware of.
Never thought the mounting brackets on the 8-Track would interfere with the lap vent, doesn't look that close.
Thanks for this info.
Name:	67 DS AC LAP VENT BRKT -8 TRACK 1.jpg
Old 07-10-2022, 09:36 AM
@gto4ben. Thanks for the information. Mine is AC only. I would not have thought there was a different bracket for 8-track. Maybe I will post in the parts wanted first to try and find one.
Old 07-10-2022, 03:35 PM
Thank you. Explains why the part is in a box labeled underdash A/C vents . Here's a photo with dimensions for the A/C with 8trk version.
Old 08-28-2022, 12:07 PM
Got scammed on this site trying to buy one from parts wanted forum. Luckily only $35.00. First time it has ever happened.
So I ended up making my own (see photo). Fit and function are very good.Thanks everyone for providing such detailed information.
