Old 06-01-2019, 08:06 AM
F9driver's Avatar
F9driver F9driver is offline
Default Correct decal?
Good morning Super Duty nation...
I have two SD cars manufactured in July of ‘73. Two different decals, (one auto, one 4-speed) which one is factory correct? Is there a difference in auto and 4-speed?
Thank you in advance,
KW
ID:	513342   Click image for larger version
1-of-72
1-of-276 (82?)
1-of-110
  #5402
Old 06-01-2019, 08:45 AM
Formulabruce's Avatar
The pic on the left, however it should be down ( in this pictures case, to the right) about 1.5 inches. ( Ref. June '73 core support.) This is not a SD specific part. What are the dates on your core supports?
  #5403
Old 06-01-2019, 09:09 AM
Brewster's Avatar
Brewster Brewster is offline
Correct original decal has rounded corners however there is NO sealant between fan shroud and radiator support.
  #5404
Old 06-01-2019, 10:06 AM
Held for Ransom's Avatar
Agree, the rounded corners piece.
https://www.corvettecentral.com/c3-6...-shroud-263904
ID:	513348   Click image for larger version
So long, farewell.
  #5405
Old 06-01-2019, 03:50 PM
F9driver's Avatar
Thanks guys...
Brew- ya scared me, thought I was gonna have a weekend project removing sealant! The picture looks like there is goo in between the fan shroud and radiator- just the lighting and the rough edge of the shroud...no sealant.
I’ll Dig up the core support numbers in a bit...
1-of-72
1-of-276 (82?)
1-of-110
  #5406
Old 06-01-2019, 04:16 PM
The OP picture on the right looks too small
  #5407
Old 07-23-2019, 06:43 PM
gilg gilg is offline
What is you opinion about this 1974 SD 455 AUTO Engine Valve cover Decal try to recreate? i dont have example from 1974 i used 1973 instead and change the engine code
ID:	516237   Click image for larger version
Name:	09 1973 XD SD 455 Auto.JPG
ID:	516238   Click image for larger version
Name:	10 1973 XD SD 455 Auto.jpg
  #5408
Old 08-03-2019, 10:19 PM
necdb3's Avatar
necdb3 necdb3 is offline
Mecum Harrisburg sold a 73 BG SD auto for 80K.
Sounds cheap for a 73 SD
  #5409
Old 08-04-2019, 12:58 PM
Brewster's Avatar
Keith good deal. Now you can dip your hood spring ends in some blue/green paint to mock originals
  #5410
Old 08-05-2019, 01:41 PM
Especially for a Bgreen car with high option content.
It looked like a really nice car by the pictures on their website.
Did anyone get to see it , or know any further details on the car ?
VIN claimed to be lowest known ?
  #5411
Old 09-25-2019, 01:24 PM
sdbob sdbob is offline
There is discussion in street section on pvc valves. Does anyone know why 74 SD455 had pvc in valve cover and not valley cover? My valley cover has plug. Not enough room for line?
  #5412
Old 09-25-2019, 03:00 PM
frank.g frank.g is offline
The SD455 engine was the only engine Pontiac installed an 80 lb. oil pump in. That pump created so much oil distribution that the PCV valve in the valley pan would suck oil into it, not very desirable. Pontiac relocated the PCV valve in the rocker arm cover to solve this issue.
  #5413
Old 09-25-2019, 04:13 PM
Aluminum Chief's Avatar
Aluminum Chief Aluminum Chief is offline
Default Brewsrer Green
I did see the car at Mecum, very nice car but not a fan of a Green T/A with ugly beige interior. KC
Old 09-25-2019, 09:05 PM
Thanks Frank. Hmm I wasnt where of pumping problem. My all original SD still has the 80 psi pump. When I built my other SD, I used the 60 psi spring in an original SD pump. I had a 421 in a 63 GP in the 70s. I pumped enough oil in the valve covers,about 5800rpm, it came out on headers,scary.
  #5415
Old 09-26-2019, 10:35 AM
Turns out, in stock form, the 80 lb. pump was overkill - rule of thumb is 10 pounds per 1000 rpm. 60 lb. pump is perfect for these high torque Pontiac engines, in stock configuration. The 80 lb. pump was most likely supplied because engineers expected this engine to be modified for racing applications. Remember the motor had ports for installing an external oiling system, among other features.
The 60 lb. spring was good choice for a stock rebuild.
What year is your all-original SD? If 73, you might want to pull distributor and check wear on teeth of the distributor gear. Quite a few of the 73's seem to have suffered oil starvation at the gear, with resulting gear failure. It seems that the 74's improved the oil supply to the distributor (larger port) , as gear failure was not as common on the 74's.
  #5416
Old 09-26-2019, 08:23 PM
1974,40k. I ordered car, non air or power,waited 5mos.Drove it to Norwalk at least 12 times,showed Sat,raced Sunday then drove it home.The other is a put together car. Now for the unbelievable story. Back in 75 I needed a distributor for my 65 Lemans. So went to local salvage yard.got to scrap pile started rolling over blocks saw Pontiac oil pan,grabbed distributor. Here it was a sleeved distributor, I thought RA V OR SD455. Block,8 rods pistons oil pump there. So I walked in side said how much for junk Pontiac block,he we got to get 35.00,I hymmed,i dont know,ah ok. The block was an SR with a sleeve in # 5.strange!! Bored .030 with new crank ,pistons same rods.Found used 73 SD heads and intake,new 455 crank.Have over 200 runs on engine. Me building in backyard I call it,3800lb 2nd gen,73, car ,stock GM parts. 3200 stall,3.73,12 teens,110.Around here. I know more cam and springs will wake it up but it doesnt cost much to run.
  #5417
Old 09-27-2019, 08:27 AM
Great story! Junk yard finds were always a lot of fun. Too bad it's a lost pastime. At least around here, junk yards have gone the way of the dodo bird in NJ.
  #5418
Old 09-27-2019, 07:28 PM
Talking
I liked to go every Saturday esp when raining usually got better deals-$$. That was my best, I wish I had got some GTO parts cars had many chances, money and space. Yes around here too,no 60s - 70s cars.
  #5419
Old 10-11-2019, 12:43 PM
Ebay.. 73 SD Formula.. Is anybody here familiar with this car?
https://www.ebay.com/itm/223699589679?ul_noapp=true
1974 Formula 400 - Ram Air automatic
  #5420
Old 10-26-2019, 12:37 PM
starlightblack's Avatar
starlightblack starlightblack is offline
This is criminal:
https://barnfinds.com/hiding-in-plai...rans-am-sd455/
