Test & Tune Ask questions about the features and functions of the Forums. |
Error message when posting
Each time I make a post, I get the following error message:
"This forum requires that you wait 20 seconds between posts. Please try again in 5 seconds." The message posts OK, but why the error message? I can't even begin to type fast enough to type a new post within 20 seconds! Jon
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
I have been noticing this for many days now - something similar happens if you happen to edit a post (as i often do when I notice a typo right after clicking "post");
It's like the server is delaying things. If you make the mistake of clicking "ok" after the initial posting, it will repeat your post a second time; If you're editing, it's glacially slow to show the edited post...
I’ve emailed the forums admin about this issue, let’s hope there’s a solution coming soon.
WHOA!!
I just saw a lightening fast “quick reply” - maybe it’s fixed? EDIT: This one was lightening quick too!!
1970 Formula 400 Carousel Red paint on Black standard interior A no-engine, no-transmission, no-wheel option car. Quite likely one of few '70 Muncie three speed Formula 400's left. 1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing) 2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs) Last edited by unruhjonny; 05-01-2023 at 09:23 PM. Reason: adding to the reply |
Thank you B-Man!
No problem when posting this reply! Jon
it appears to be doing it again.
Let's see if it happens for me.
edit: no problems here, my post went through right away. |
Maybe I can help.
I use two different computers for posting, one with Windows 7 Pro operating system, the other with Windows 11 operating system. There have been zero issues when using the Windows 11 operating system. When using the Windows 7 Pro operating system: Posting a new topic works fine, no error, although it takes about 20 seconds. Replying to an existing topic gets the error every time. Hope this helps. Jon
Thread Tools | |
Display Modes | |
